There is no maximum travel as far as I have found; you can just keep going round and round.
To avoid having to 'unwrap' by the same number of degrees to take the Rotary home you have to turn on Quick Rotary G28 and CIRCLE WRAP.
Setting #108 is Quick Rotary G28.
CIRCLE WRAP is one of the items under PARAMETER 43, put a 1 here.
Depending on the age of your machine you may find that CIRCLE WRAP is a Setting not a Parameter.
LinkBack URL
About LinkBacks
) If you have a combined XA move, the linear feedrate is 'boss' anyways, and feedrate is modal and does not need to be declared on every line unless you wish to change it.
