Old 12-23-2007, 09:16 AM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
mini mill spindle fan
the fan on the top of my z axis seems to cause excessive vibration when running.
It will vibrate tools off of the tool tray and i can see the vibration in an indicator needle if i happen to be using it when the fan is on
is this normal? what's the fix?
Old 12-23-2007, 09:39 AM
I don't think that is normal . Check that nothing has got stuck to one of the blades. I once had a fan pick up a bit of tissue paper on one blade and it shook like crazy.
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
spindle fan vibration on mini mill 1ctoolfool Haas Mills 1 04-26-2007 07:31 AM
R8 mini mill spindle for wood? ZipSnipe Mechanical Calculations/Engineering Design 9 12-29-2006 10:57 AM
X2 mini mill spindle distance? ZipSnipe Benchtop Machines 0 05-04-2006 09:19 PM
Mini Mill Tool Stuck in Spindle esphobby Haas Mills 13 02-21-2006 09:29 PM
