Old 12-04-2007, 01:25 PM
L.Kiefer is on a distinguished road
ERROR MESSAGE; File disk offset....
I have a Haas VM3 Mold maker.
The control randomly throws an alarm with the following error,
"File disk offset"
The only way I can clear this error is to power down the machine and restart.
Has anybody experienced this before? If so were you able to find a real solution?
Thanks.
Old 12-05-2007, 08:18 PM
cjablonski is on a distinguished road
What software version is on your machine?
I've had that problem when using Ethernet and went away when the mill software was upgraded from M13.09F to M13.16F
Old 12-06-2007, 07:41 AM
I was thinking that an upgrade may solve this problem.
I have an older version.
I will give this a try, thanks.
File Upload from Disk Big"E" Haas Mills 27 06-16-2007 08:35 AM
Boot disk for EZ-Track DX, batch file? mmm2003 Bridgeport and Hardinge Mills 8 01-31-2007 11:47 AM
G83 error message HBFixedGear Fadal 14 01-30-2007 09:42 AM
Mach III error message-Help bherr Shopmaster/Shoptask 5 05-19-2006 07:11 AM
gibbscam error message donder GibbsCAM 2 05-31-2005 12:16 AM
