I've got a bit of a cycle time problem and a question I hope someone can help me with. I've got Haas VF-2 with a 25 tool carousel. Here's my problem, I'm running a job that requires 4 program stops (M00) where I bring the spindle down with a pin in a tool holder to load the pc up to. My next tool is an end mill that is 10 tools deep in the carousel, so the pin rapids back to Z0 while the carousel indexes slowly to find my end mill. Is there a way to get the end mill to get into the next tool position before my M00? I'll post a portion of the program so you can see what I'm doing. Thanks Code: (LOCATING PIN) N1 G00 G17 G20 G40 G49 G80 G90 G98 G53 Z0 T1 M06 G110 X.3125 Y-.17 G43 Z1. H01 G00 Z-.2 M00 (LOAD PC TO PIN) G00 G80 Z1. M09 G49 G53 Z0 (FACE MILL 1ST SIDE & MILL OAL) N2 G00 G17 G20 G40 G49 G80 G90 G98 G53 Z0 T2 M06 S6000 M03 G110 X.3 Y-.17 G43 Z1. H02 M08 G00 Z-.025 G01 X-2. F45. G00 Z.1 X-1.249 Y-.615 Z-.385 G01 Y.275 F40. G00 Z.1 X.249 Z-.385 G01 Y-.615 F40. G00 G80 Z1. M09 G49 G53 Z0 |
| I think you can put the next tool number ahead of the M00 and the changer will pre-position that tool. That is just the tool number Tn without the M06 command. My machines see the next tool in look ahead and pre-position well before the change is called. I have not used M00 and I just wonder if that blocks the look ahead. It would be logical if it does.
| Thanks for the reply Geof, I'll give that a try in the morning. Yeah, the M00 does stop the look ahead that's why I was wondering if there was another way to get the next tool ready before the stop. It's adding about 40 extra seconds to my cycle time. Thanks again for the tip and I'll let you know if it works. |
| Yes it's the dual-arm changer. I didn't realize I could call up the next tool like that. Geof also recommended I try that method, I knew it was going to be something stupid easy! Thanks guys, much appreciated. |
| VF-2SS Tool Carousel Problem | JoBwan | Haas Mills | 18 | 05-25-2011 01:07 PM |
| tool carousel position problem | Greg 24 | Haas Mills | 4 | 10-19-2009 03:44 PM |
| tool carousel alignment | rubino2112 | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 12-27-2006 12:26 PM |
| Spindle Bearing/Tool Carousel Motor??? | AdvancedMfg | Industrial Hobbies (Support forum) | 0 | 12-04-2005 09:25 PM |
| Stop/start a program | jimglass | TurboCNC | 3 | 06-10-2003 08:59 AM |
