I have a 2000 TM 1 that has run with no problems since we sat it on the floor in Nov. 2000. Now it has started a turret rotate fault when indexing and it happening more and more. Any suggestions would be appreciated. |
| Very often turret index faults are due to contamination on the proximity sensors or microswitches. There are two; one detects the position for tool 1 and the other counts the number of tool spaces. They are not easy to see but if you remove all the tools, do a tool change using 5% Rapid and hit Estop while the spindle is lifting you can see inside the changer. There is a sensor on the track for the shuttle so you can see what they look like and you will see the two inside. If they have a chip stuck on them that will be your problem. If they are microswitches they may be gummed up with coolant residue.
| Have a look at the picture in the first post in this thread. http://www.cnczone.com/forums/showthread.php?t=22545
| V2007 Rotate | TZ250 | BobCad-Cam | 5 | 10-14-2007 12:39 PM |
| R2E3 quill rotate? | cut more | Bridgeport and Hardinge Mills | 2 | 09-13-2007 06:38 AM |
| Rotate and copy | bdrmachine | Solidworks | 6 | 02-02-2007 09:56 PM |
| Bolt on Turret 'v' VDI Turret | scappini | General Metalwork Discussion | 0 | 07-20-2006 06:59 AM |
| copy and rotate, help (okuma) | zooloader | G-Code Programing | 13 | 06-26-2005 07:01 PM |
