Results 1 to 3 of 3
Thread: Rotate a G150 pocket cycle
    Apr 2006
    I have been trying to rotate a G150 pocket using G68 and it don't seem to
    work. Is there a setting I need to change or some other trick to make it work
    Jul 2005
    Parameter 57 COMMON SWITCH 1 the one labelled ENA ROT & SC should be a 1 for Rotation and Scaling to be enabled. If it is a 0 you do not have rotation.
    This is an option that needs a code number to activate but I don't know the cost.
    Apr 2006
    I have Scaling & Rotation on
    Edit
    I don't think it is possible. I have been messing around with irregular shapes with islands and I can see that it would be impossible to rotate all the cut paths needed to do these weird shapes with islands.
    Thanks for looking anyway.
    Geof
    It is on. We have it on all our Haas Mills. Can't get along with out it.
  1. V2007 Rotate
    By TZ250 in forum BobCad-Cam
    Last Post: 10-14-2007, 01:39 PM
  2. Rotate/Translate Axes?
    By jim_stoll in forum Dolphin CADCAM
    Last Post: 10-09-2007, 03:29 PM
  3. Rotate and copy
    By bdrmachine in forum Solidworks
    Last Post: 02-02-2007, 10:56 PM
  4. G150 question
    By Zeekh in forum G-Code Programing
    Last Post: 01-06-2007, 11:27 PM
  5. G150
    By DavidJSwanson in forum Haas Mills
    Last Post: 03-22-2006, 02:09 PM
