Old 11-25-2007, 01:12 AM
smittys800 is on a distinguished road
TM-1 Harmonic noise on "Y" Axis
Tried the search, but came up empty.
I removed the Y axis handwheel, and get a harmonic noise, no matter the speed of the Y axis. I made a bushing to take the place of the wheel, same noise. RE-installed the handle, noise gone. Is the Handwheel some sort dampner by chance.
I removed the handwheel so my vise handles don't get caught by the wheel, and I don't really want to cut the handles.
Any ideas,
Smitty
Old 11-25-2007, 01:51 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Can't you just pop the caps and take the knobs off the handwheels? I'm already looking at that on my TL-1.
They've shortened the knobs on the latest version of the TL-1 (and probably the TM-1 as well) but they still stick out enough to whack you if you aren't paying attention.
Greg
Old 11-25-2007, 08:41 AM
Originally Posted by smittys800 View Post
.... Is the Handwheel some sort dampner by chance....
It sounds like it is acting as a damper but I don't think it is intended for that. I have a TL1 and the Z axis would oscillate a bit during a rapid and after I took the handwheel off that went away.
I think you just change the response characteristics of the system when you remove the handle; the inertia is now different.
There are parameters than can be adjusted: Parameter 267 Y SWITCH B; Y P GAIN, Y D GAIN, Y I GAIN and also Y ACCEL FEED FORWARD (I think). I had a new MiniMill and these had to be adjusted by the Haas Tech to stop the X axis oscillating. I don't know the details but maybe someone will post more information.
Old 11-26-2007, 06:21 AM
Shotout's Avatar
Shotout is on a distinguished road
Any ideas,
Smitty
Like Geof said the parameters can be adjusted to compensate. We had that problem on one of our TM-1s, called Haas tech support and told them what it was doing and they told me the same thing as Geof said about the Parameter values. I read them the current values and they told me what to change and it fixed it. Give them a call they'll be glad to help.
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
Old 11-26-2007, 09:42 AM
Thank you Gentleman,
Will call later this week and get this dealt with.
Smitty
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 09:53 AM
FANUC "Yellow Cap" servo motors -buzzing noise brgrii Fanuc 2 06-03-2007 08:21 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
TAIG "head" makes alot of noise Smertrios Taig Mills & Lathes 17 02-25-2006 04:25 PM
