Results 1 to 4 of 4
Thread: 2006 VF2 - Spindle Encoder Z CH Missing?
    Aug 2006
    Figures, I had my local HFO do a preventative maintenance on the machine, and after about an hour of use, I get the following codes:
    173 Spindle Encoder Z CH Missing
    116 Spindle Orientation Fault
    215 Spindle Z Fault
    I can rotate the spindle by handle and see the rpm on the screen, but if I try to orient the spindle, sometimes it will orient once, otherwise it will turn partially and error out, and sometimes it won't move at all and just error out..
    I tried to call my local HFO today (Friday afternoon, day after Thanksgiving) and just my luck, nobody is working (except me! ).. Anyone have any ideas on what I can check?
    Specs: 2006 VF2 (no gearbox, just a 7500 rpm machine)
    Software Version: 15.03D
    Feb 2007
    Ireland
    Hi lo cash
    I would check the plug on the spindle encoder is tight and follow the lead down from the encoer i think there is a second connection before it gets to the controle pannel make sure all plugs are tight
    best of luck
    Aug 2006
    Apparently, after talking to a buddy with a brand new 2007 VF2, this is common with the newer Haas encoders.. His failed after a few hours of use at 10,000 rpm, and the technician told him it was a common failure on newer machines.. I think I need to sign up for the Haas repair class, it may pay for itself in the long run (if I buy more of these things!). Since the machine is still under warranty, I'm hoping for an expensive part that is in stock at the local HFO, so it can be fixed Monday. If they can't get out to fix it on Monday, I may be tearing it apart myself, as I'm already down a day on this job due to the machine maintenance last week..
    Thanks for the help, I'll post the results!
    Aug 2006
    It was the encoder that failed, luckily I didnt have to pay for it, as it was under warranty..
    Now that my warranty is about up, what will break next?
  1. spindle encoder belt
    By RICKG in forum Fanuc
    Last Post: 10-22-2007, 07:14 PM
  2. spindle encoder
    By heilcnc in forum LinuxCNC (formerly EMC2)
    Last Post: 09-10-2007, 10:12 AM
  3. Question about missing tool in spindle
    By AMCjeepCJ in forum Milltronics
    Last Post: 01-31-2006, 12:55 AM
  4. Spindle speed controler and encoder
    By Parameter in forum Mach Software (ArtSoft software)
    Last Post: 12-10-2005, 07:30 PM
