I don't remember the encoder belt having any effect on spindle orientation.
Water in your air lines, low air pressure, air leaks, gummed up solenoids and/or shot-pin assembly can all slow the orientation process enough to cause an alarm. You could increase the delay time for the alarm (Parameter 66), or you could slow down the orientation speed (Parameter 73 & 74). Make sure you record the original values...
LinkBack URL
About LinkBacks
