Old 11-17-2007, 12:43 PM
akedward is on a distinguished road
VF-2 Cutting 1/4" Mild Steel plate
I'm going to cut some 1/4" mild steel plate on my VF-2 for an engine mount welding jig and I'm looking for a cheap way to fixture the plate above the table. I have use aluminum before so I could go full depth but it gets kinda spendy.
I suppose I could just put spacers at certain locations and rely on the stiffness of the material to support itself seeing how the tolerances on these plates are no more than +/- .010" .
Any thoughts for cnc newb?
-Thanks
Old 11-17-2007, 04:52 PM
timan is on a distinguished road
What are the dim's of the plate? Can you use a couple vises?
Old 11-17-2007, 05:01 PM
DEAN is on a distinguished road
MDF subplate?
Old 11-18-2007, 11:45 AM
PBMW is on a distinguished road
I do jobs like this all the time. I use a sub plate
It cuts into the plate by 10 or 20 thou.
Old 11-18-2007, 12:28 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
+1 for the MDF subplate.
Or use a bunch of carefully placed 123 blocks under the plate clamping points.
I did a piece of 1/2" aluminum plate (22x10) that way. I basically used a 1/4" endmill to 'part off' the finished piece (irregular outline). I clamped the four corners on 123 blocks and put a few more under the plate in the center for support. It chattered a little in the unsupported areas but worked out fine.
To cut it out, I did shallow laps around the periphery. I think the next-to-last cut left 0.025" and I made sure the cutter wasn't 'buried' on its full face (did a clearance pass on every depth so the wall of the 'part' only saw a finish pass).
On the final lap at 'full depth' the part just quietly separated from the edge, the burr broke and the part shifted away from the raw material. It's a little risky but worked in my case.
It left a bit of a knife edge all the way around but that was easy enough to remove with a file.
Greg
Old 11-18-2007, 01:26 PM
I don't mean this to be inflamatory, so please don't take it that way. But you guys must not be doing this for a living.
I cut stuff like this all the time. Stick an endmill in full depth and cut the part. I don't step down as that just wears the corners of the cutter prematurely nad takes 5 or 6 times as long to cut the part. I make one rough pass and one finish pass.
My mini mill won't like full width cuts with a half inch cutter but 1/4 thick material is a no brainer.
I cut 2" thick parts on my box way machine full depth and full width. No issues. I cut everything from 316 to 1018 and alum this way. Every extra rough pass is money out of my pocket.
Old 11-18-2007, 08:09 PM
Smile
You are 100% correct!
Old 11-18-2007, 09:04 PM
And thank you for sharing it. That's why I'm here: help where I can and learn where I can.
In the case of the part I was making, cosmetic finish was very important on the edge and I only had one piece of material and it had to be done the next morning.
A 2X deep, fully buried 1/4" endmill in 6061 seemed risky. If I broke the endmill, it wouldn't be ready the next morning. If I ruined the material, it wouldn't be ready the next morning. I had all night but only one cutter and one plate.
What about stainless? I am about to start working with a lot of 0.25 and 0.325" stainless plate (alloy TBD). I need to do profile milling, full depth with 0.25" endmills. Any recomendations?
Greg
Old 11-19-2007, 05:38 AM
djr76's Avatar
djr76 is on a distinguished road
Just like tinman said, get the shortest flute you can get that will cut the job. Carbide rougher with flood coolant at full depth. I work for an oem making food processing equipment. We found it to be cheaper to buy whole sheets and have them pre-lazer cut, then finish machine them.
Old 11-19-2007, 11:05 AM
Baketech is on a distinguished road
Ditto on the sub-plate suggestion. If you do a lot of plate work it's a good idea to have a nice bottom plate with a common grid of holes in order to quickly mount consumable plates to it. You can keep templates in your CAD system in order to quickly fixture jobs and order appropriate sized material.
Low Head Capscrews are your friend here...
The shorter head dimension (compared to SHCS) allows more resurfacing cycles of your fixture plates....
  #11   Ban this user!
Old 11-23-2007, 08:56 PM
Thanks guys, I like the MDF subplate idea, much cheaper than aluminum and should work fine for the stuff I'm cutting.
  #12   Ban this user!
Old 11-24-2007, 06:57 AM
Vern Smith is on a distinguished road
Tell me a little about the tolerances that one can expect from MDF used as a sub plate. I can readily see where it would work well for cutting out sections of plate. I have a lot of jobs that require machining features onto the face of the plate as well as a final operation to run an EM around the outside to separate the part from the stock plate. Is the MDF thickness uniform to within say .01"?
Vern
Cutting thick steel plate Woodenspoke General Metalwork Discussion 25 07-11-2007 11:58 PM
Cutting 1" Mild Steel 3DSteve CNC Plasma and Waterjet Machines 14 06-14-2007 04:58 AM
RFQ - on 1/2" mild steel plate BullCreek Employment Opportunity 5 07-10-2006 06:31 PM
cutting long cut in 1/2 steel plate ZipSnipe General Metalwork Discussion 7 06-09-2006 06:47 AM
Cutting 3/8 steel plate BlueC General Metalwork Discussion 2 05-21-2004 10:06 PM
