Old 11-15-2007, 05:41 PM
Janos is on a distinguished road
Feeds & speeds Question
Hey all, I have a question for you. We have a piece of 316 stainless that has to go on a BIG diet, Sooo we have decided to put the shell mill on the job. But...... I would like to get a good starting point with the speeds and feeds. We typically run a TON of aluminum so this stuff is a bit new to me.
Thanks Janos
Old 11-16-2007, 01:06 PM
cutting edge is on a distinguished road
A little more info would help. What diameter face mill? How many inserts? What size machine?
Old 11-16-2007, 04:04 PM
Ooops, sorry!! Had a very long day and I wanted to end it.
3" Valenite sheer mill ( I will have to get back with you on the inserts. )
6 inserts
Haas VF-4 w/ 20 Hp
Right now it has a castrol lube in it fo alum but when we just faced the part the cuttung edges got wiped out.
Thanks janos
Old 11-16-2007, 05:18 PM
I run 316L alot. I run a 3 inch face mill(6 inserts) at 250 rpm and 5 ipm on a VF3SS. I'm cutting .213 off a part that is 2.5 inches wide. I take it in two steps of .106 I can cut about 40 parts like that. Obviously you can go a little faster but your tool life will suffer.
I am using RTW inserts. The part number is SEHW43A6. Hope that helps.
Old 11-17-2007, 07:17 AM
Thanks, I appreciate you help!
Janos
Old 11-17-2007, 07:49 AM
jackson's Avatar
jackson is on a distinguished road
This is what my software put out it is pretty accurate you may change a bit as was said for tool life
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 11-17-2007, 07:55 AM
djr76's Avatar
djr76 is on a distinguished road
Might want to run that dry as well. I face mill 304 structural at work and run it dry with good results. The coolant might be shocking it to much, and make sure your using a tough ss grade like vp5135.
Old 11-17-2007, 12:40 PM
DONNYBRASS is on a distinguished road
software
what type of software is it and whats it called. and were can you get it.
Old 11-19-2007, 08:09 AM
jackson's Avatar
http://www.mrainey.freeservers.com/ Here is the site i recommend getting the ME Consultant Pro & ME thread Pal as you will see from the site they are worth the money
Old 11-19-2007, 09:42 PM
The guys I am asking the info for got a .750 valenite indexable shoulder mill and went by what the salesman suggested which was 900 rpm and 15. ipm at .03 deep and quickly dispached a set of inserts. I took your info and adjusted them to the new tool and it seemed to work quite nicely. It was still buzzing along when I left it.
What kind of coolant do you use for it? They bought a Castrol product that is clear. The kind we use at my day job is Basocut Swisslube (I think my spelling is correct) It works great on pretty much everything.
Thanks Janos
  #11   Ban this user!
Old 11-20-2007, 07:51 AM
PBMW is on a distinguished road
I have a recurring job in 316. Nasty stuff. I have a 2 1/2" face mill with round incerts. SECO REHR 1605M0T m14 T25m. I turn these at 382 rpm and feed it at 6 to 8 ipm. Takes .100 a pass full width. I can buzz along for quote a while before I have to turn the buttons.
  #12   Ban this user!
Old 11-20-2007, 05:23 PM
Thanks Janos
I use Blaser BC40 NF. I am currently running the stainless job that I told you about. I tried something a little different. I was just running a clean up pass on the part and ran the 3 inch face mill at 509 rpm and 18 ipm with a depth of cut about .020. Part is 2.5 wide and 6.25 long. I ran about 60 parts like this before the inserts let go. I haven't tried taking the larger cut yet. Will report back later.
Glad to hear that worked for your friend!
speeds and feeds bdrmachine SolidCam 6 04-12-2008 08:15 AM
tungsten feeds and speeds question!?! dcrblazer General CNC (Mill and Lathe) Control Software (NC) 2 11-09-2007 03:35 PM
Speeds and Feeds wdp67 Benchtop Machines 2 07-10-2007 02:06 AM
feeds and speeds JpBinc General Metalwork Discussion 4 10-03-2006 12:48 AM
feeds and speeds Mortek Hard and High Speed Machining 6 02-28-2004 03:59 AM
