Old 11-15-2007, 02:47 PM
jybute is on a distinguished road
Air Blast
hi all, I am looking for an air blast system for our VF6, the one it came with from the factory is not very good. Something aftermarket that will not interfere with the tool change (carousel type). I have just started looking so........
Old 11-15-2007, 10:47 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
What is it that you don't like about the system? Are you using it for cooling or clearing chips & coolant at the end of a cycle?
I assume you're asking about the telescopic system on the adjustable mount. I have it on my VF-2 but I've only played with it so far.
Greg
Old 11-16-2007, 07:40 AM
Rocko1 is on a distinguished road
jybute, try Exair they have great products. http://www.exair.com/Cultures/en-US/...tion/Products/
Old 11-16-2007, 08:45 AM
I am using it to clear chips during an operation. I cant seem to get enough pressure out of it. This isnt necesarily a fault of the machine, but the tool we are running produces so many chips, so quickly, that the 1000psi through coolant system isnt even strong enough. We have to come up with something soon, cause these endmills are amazing and it is a shame that we cant use them properly.
Old 11-16-2007, 10:08 AM
hutch07 is on a distinguished road
Wow,
What type of endmills are you using and what are you cutting? Can you add more volume of coolant like the Fitz-Rite endmill holder? It has holes in the end to blast chips. This worked for me on an aluminum job.
Let me know.
Old 11-16-2007, 10:32 AM
The mat'l is 4145 Hmod (28-32Rc) I am using an ISCAR 1/2"Ø Solid carbide. 2x doc (thats right 1" doc) 700 sfm .002 ipt. Lots o' chips. My through coolant is coming through the collet. What system is that, Fritz Rite? Where do I find this?
Old 12-15-2007, 07:14 AM
FitzRite
jybute,
The FitzRite holders have holes in the end of them that may give you more volume than a collet. www.fitzrite.com. Can you "T" off your coolant line and run an additional line into the machine with a high velocity nozzle?
Those endmills sound great.
good luck
Can you bead blast plastic? MagTDK General Material Machining Solutions 5 08-03-2007 08:02 AM
mazak air blast rhurt Mazak, Mitsubishi, Mazatrol 1 03-05-2007 09:34 AM
Air blast thru spindle ajl6549 Mazak, Mitsubishi, Mazatrol 5 02-09-2007 06:13 AM
Convert your router to cut vinyl and sand blast as well. ynneb Printing, Scanners, Vinyl cutting and Plotters 17 01-11-2007 09:09 PM
