Old 11-13-2007, 10:48 AM
Ford25 is on a distinguished road
VF4 gear fault?
from what i've heard from this is that its not in a gear, that its floating inbetween high and low. The alarm will not clear and the air pressure is fine. any help i can get on this wonderful alarm would be awesome. have a great day!
Old 11-13-2007, 12:12 PM
JACKOFTRADES is on a distinguished road
I read earlier in the forum that unhooking the air and hooking it back up might pop it into gear.
Old 11-13-2007, 02:34 PM
HAILINHAAS is on a distinguished road
Smile alarms and fixes
Read the thread "alarm and fixes" a little instruction on what to do by JoBwan ... let us know if this fixes your problem.
Old 11-17-2007, 01:00 AM
SKEETO's Avatar
SKEETO is on a distinguished road
It sounds like the servo is corroded. We have had this problem in the past and it was the result of moisture in the air line. If you need a quick fix, try putting M41 OR M42 (high and low gear override codes) in the program in the line above your spindle rotation and speed comand . Note: Surface footage may need to be adjusted if tapping or heavy machining is taking place. Hope this helps.
Old 11-26-2007, 10:57 AM
Thanks for the help! I drilled the holes in the solenoid and put everything back together and it works great again. There was a little bit of debris that may have been blocking the holes, but i just wanted to thank ya'll once again for the help.
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
VF3 spindle high gear fault alarm #117 help! JHR1 Haas Mills 14 01-01-2010 10:39 AM
ATC noise fault logos AjaxCNC Control Products 3 07-27-2007 06:11 PM
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-06-2006 11:06 PM
inverter done after #9 fault logos Fadal 1 03-22-2006 08:53 AM
