If I am milling a bunch of small 2" x 2" rectangular blocks from a 12" x 24" x.5" plate I can mill one side and then flip it over to complete the milling. I will also do the same for 2" circles. How I hold individual pieces when I flip the plate over? I thought maybe I need some sort of a female subplate attached to a vacuum system, but that seems like a expensive option and I don't know if that will work. Any other suggestions? I probably should ask in the work holding forum, but this forum seems to have higher traffic and parts will be milled on a Haas . . . . for those that also reads cnczone forums. . . my apologies. . it's the same post.Thanks, John |
| If I understand you your trying do something like what I have below, see attached jpg. These tabs are .250 ± .001 thick. I needed 32 of them so I cut them .26 deep into .375 stock. I took the milled pc to the bandsaw and cut the surrounding unmilled material away and then seperated them lengthwise and cut those in half ending up with 4 pieces of four. I then face milled the sections of 4 to dimension and deburred them. For the circles a set of vise softjaws cut to hold the circles would do the same thing, or if you can turn them in a lathe, part them off long. Turn a small step almost deep enough to hold the finished part in a set of softjaws and then face the parts to the finish length. I have a poultry plant that orders 1.750 OD, .501 ID, washers .625 thick. These require a pretty fine surface finish but it was also quick.
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| Shotout, Thanks for the suggestion, but I don't have a bandsaw. . . I got a suggestion from another forum to drill clearance holes on when I mill the top side so I can access the clamps after I flip the plate over. I'll give that a try . . . if doesn't work I'll look into getting band saw. . . I think the process will go faster if I can maximize the number of squares/circles milled at one time. . . but then again I may only end up milling a few dozen pieces. . . thanks again, john |
| Holding down your parts | Jamf2 | Work Fixtures and Hold-Down Solutions | 63 | 07-02-2010 05:25 AM |
| holding threaded parts to mill | Metal_twister | Work Fixtures and Hold-Down Solutions | 7 | 01-14-2007 05:56 PM |
| Q: Non-marring Working holding | Deviant | Mini Lathe | 4 | 06-21-2005 01:51 PM |
| Holding small parts? | Ken_Shea | Machine Problems, Solutions , Wireless DNC, serial port | 16 | 06-03-2003 04:28 PM |
