Old 10-26-2007, 07:20 PM
jaimeeduardo is on a distinguished road
many alarms this mornig on hass mill vf3
hi, hope you didnt have a bad day as i, this mornig i had the following alarms on the hass cnc mill:
201 parmeter crc error
203 lead screw crc error
261 rotatory crc error
250 prog data error
212 prog integrity error
135 x motor overheat
138 a motor overheat
122 regen overheat
119 over voltage
117 over voltage shutdown
220 A phasing error
624 pocket-tool table error
903 cnc machine power up
160 low voltage
254 spindle motor overheat
I didnt have any failure on this machine before, so i dont have any maintenance manualrs, diagrams, software or any of those, only the operator manual. Dos anyone know how to change the parameters? i need to program it from the rs232? when it start up and show the alarms it shut down after 15 seconds, how do i stop it?
Jaime Eduardo
Old 10-27-2007, 01:03 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Jamie,
Looks like a bad day alright.
Is it under a factory warranty ?
Wayne
Wayne Hill
www.codemangler.com
Old 10-27-2007, 06:02 AM
serviceman's Avatar
serviceman is on a distinguished road
sounds like your battery died what is in setting 26 of your machine if the serial # is not correct you need to reload your pars and settings etc.
Old 10-27-2007, 07:59 AM
The cnc doesn't have warranty anymore, i also think my problem is the lost of the parameters, but how do i program them again? can i program from the operator panel or do i need to connect the laptop from behind the machine? were can i check the parameter 26?
As you can see, i need step by step help, because this machine never fail me again.
Thank you
Jaime Eduardo
Old 10-27-2007, 02:34 PM
Rocko1 is on a distinguished road
This brings up a good point. Can someone make a backup from the Haas control to the floppy?
Old 10-28-2007, 04:51 AM
daleman is on a distinguished road
yes back up copys can be made when we had our machines installed we asked the tech if he could make us a copy of the machine parameters on to floppy he did hopefully we will never need them
Old 10-29-2007, 09:39 AM
HAILINHAAS is on a distinguished road
the parameters should be backed up on a floppy that is inside of the manual or inside of the control cabinet. It sounds like the battery on your processor is going bad.
Old 10-29-2007, 10:19 AM
I have two procedures for backing up Parameters and Settings; the key sequence is:
LIST
PAR (Now F2 and F3 should be visible at the bottom of the screen)
Type the serial number followed by .PAR
F2
Same procedure for Settings just use serial#.SET
You don't have to use the serial number but it is a good identifier.
The other procedure saves everything with the following key sequence:
LIST PROG
END
ALARMS
Type DEBUG
WRITE
POSIT
PAGE UP until you see POS-RAW DAT
Type Serial #
F2
This should save everything.
OneCNC & Hass l u k e Haas Mills 18 09-01-2008 07:08 PM
loading capacity of hass sharathss Mechanical Calculations/Engineering Design 0 07-26-2007 01:51 PM
BP knee mill or HASS CNC for prototype XXF Knee Vertical Mills 2 09-02-2006 06:00 PM
Wireless RS-232 to Hass VF-2 Gujustud Machine Problems, Solutions , Wireless DNC, serial port 1 04-12-2006 04:44 AM
Difference Hass Sl-30 And Hl-3 imwllc Haas Mills 5 06-01-2005 03:45 PM
