Recently purchased a 2002 Haas TM-1 mill. I power up the mill and send to the home positions and about 50% of the time I get a code 146 Y Limit Switch alarm. Occasionally I get a code 145 X Limit Switch alarm but usually its the Y Limit alarm. Today I powered up the mill and it homed OK. I moved it several inches off the limit switches and started writing a program at the controller. After several minutes the 146 Y Limit Switch alarm popped up. Any ideas?....or should we just check out the "alarm suggestions" that come up on the screen for solving the problem. Thanks JW Know |
| It probably has proximity sensors not limit switches and there is a chip on or very near the sensor. Find it and clean it.
| I have had this problem with my TM-1. It was always a chip (usually steel) stuck to the Prox sensor. This happened when I cut fine steel chips like you get off of an endmill taking a skim cut on the side of a piece of stock (stringy long chips) and then used a blow gun to clean off the machine. Chips were kicked up under the table and there was the problem. |
| BP R2E3 S1B8 Z-Axis limit switch | cidteach | Bridgeport and Hardinge Mills | 4 | 09-25-2007 09:47 PM |
| Y axis limit switch | raytor | Benchtop Machines | 3 | 10-10-2006 08:48 AM |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
