Old 10-22-2007, 10:14 PM
Rcky123 is on a distinguished road
93 Haas VF2 Homing Questions
When I home out my machine it alrams sometimes.
I have swapped cards and still same problem.
I have replaced the x-axis limit switch.
But the braket underneath the table was removed as well.
The one that roll upon to the switch. Which triggers it.
Does anyone know how to set this properly??
Old 10-23-2007, 07:14 AM
gar gar is offline
gar is on a distinguished road
071023-0703 EST USA
Rcky123:
Ideally I believe the limit switch should actuate 180 deg from the encoder once per revolution marker. However, the amount of hystersis and variability in the switch and the HAAS direction of use of the change of state might bias this some.
All our machines have mechanical limit switches, contrasted to prox switches, and we have never had to adjust a limit switch.
A side moving actuator on a prox switch will have a trigger point for the side motion that is a function of gap when the plate is over the prox. If the gap is 0.1" then you will be closer to the axis of the prox for the trigger point than if you have a gap of 0.01" .
Old 10-23-2007, 08:14 AM
serviceman's Avatar
serviceman is on a distinguished road
if you are getting zero ret margin too small then you need to adjust the grid offset for the particular axis then watch the dist to go on the zero ret page it should be .118 optimally just mess with the number in the grid offset parameter to change the end value.
Homing question IQChallenged Machines running Mach Software 2 06-22-2007 06:29 PM
HRT 210 homing JAVB Haas Mills 1 12-07-2006 12:44 PM
Haas Lathe Questions - Lots 1ctoolfool Haas Mills 6 08-13-2006 06:47 PM
Homing Sanghera TurboCNC 8 05-09-2006 06:47 PM
homing vs 0,0,0 planeflier Mechanical Calculations/Engineering Design 7 02-07-2006 09:02 PM
