Old 10-20-2007, 03:34 PM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
considerations for thread forming taps
need to tap 1.5" deep M8 1.25 blind hole in al 6061. first .5" is clearance with no thread. Thinking of thread forming tap for the reason of no chips, single pass,
anything i need to consider and is this a good application for this type of tool?
thanks
joev
Old 10-20-2007, 03:44 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
thats a good application for a form tap, just remember the tap drill size is different than what you would use for a cutting tap , it maybe worth looking at the tapdrill dia tolerance for that depth of hole , it would be safer tapping if you drill near the top end of the tolerance
Old 10-20-2007, 05:03 PM
AMCTony is on a distinguished road
Run your coolant very rich or use a tapping fluid like tap magic. Both of these methods have given me good results.
Old 10-20-2007, 07:50 PM
PBMW is on a distinguished road
I tap about 3500 5/16-18 1 1/4 deep holes a day .
Form taps rock.
Old 10-20-2007, 08:07 PM
Vern Smith is on a distinguished road
Do you do this in one shot or with a peck or two?
Old 10-21-2007, 07:37 AM
One shot.
I'd have to go look to be sure, but I think we're using an"M" drill. 1500 rpm. Balax taps
Old 10-21-2007, 01:14 PM
the thrill is on a distinguished road
Form taps rock.
indeed they do. i love form taps
Old 10-21-2007, 06:51 PM
JMFabrications is on a distinguished road
I run the OSG form taps in 6061 all day, I agree with everyone else.....they rock! I run my 8mmx1.25mm taps a little on the safe side at 50 SFM, that comes out to about 30 IPM and 606 RPM. I use a 7.4 mm drill which gives you about 70% thread.
Old 10-22-2007, 09:24 PM
bremenrules is on a distinguished road
OSG and Greenfield both work great. Big fan of form taps for our own projects. Unfortunately, they tend to leave a little bit of a lip at the top of the hole which can easily be cross threaded by careless customers and shop owners.
Never attribute to malice that which can be adequately explained by stupidity.
Old 10-23-2007, 06:14 PM
a lip? are you making a large enough chamfer at the top of the hole? maybe you need to change the angle of your spot drill. are you using a 60 degree center drill or an NC spot drill?
  #11   Ban this user!
Old 10-23-2007, 08:39 PM
I'm using a 120-140 degree NC spot and doing a 90 degree chamfer before tapping. It's not like a huge amount of metal's bumping up over the top of the part, but there seems to be a bit of thread before the start of the hole which can be easily bungered up. At least that's my observation with finer/smaller threads like 6-32 and 4-40. Just enough metal's being squeezed up over the top to cause issues. It's a shame, because I'm a huge fan of form taps. Thousands of parts from a single tool and not an ounce of chips to deal with....
  #12   Ban this user!
Old 10-24-2007, 12:54 PM
duenow is on a distinguished road
Tap it then spot with 90 degree, with a sharp spot. I do that all the time.
Beginner Troubleshooting and Building Considerations coherent FAQ of CNC Machine building 3 11-10-2011 01:27 PM
Thread forming crayner General Metalwork Discussion 6 03-24-2006 07:24 AM
Thread Forming Aluminum Tazzer General Metalwork Discussion 6 03-06-2006 10:11 PM
Thread Forming rrrrrgh General Metalwork Discussion 2 07-27-2005 03:50 PM
Design Considerations...Basic! Nonoriginal DIY-CNC Router Table Machines 13 02-20-2005 08:50 PM
