Old 10-17-2007, 03:04 PM
grease is on a distinguished road
Haas VF2 ALARM 127 &115
I'm Having tool changer problems. I getting alarm 115 & 127 on our VF2.
Any help would be appreciated.
Grease
Old 10-17-2007, 06:33 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Those alarms indicate a problem with the turret "rotate" motor...
Could be the motor is shot..or maybe just a bad conection..or several other things..brushes..ETC.
I would start by checking the moldex connector to the turret rotate motor..remove the side cover on the arm that comes from the machine column and holds the tool changer.. and also the front cover on the tool changer..check all the connectors there too..
It might also be that the bearing/s that the tool changer umbrella rotates on has gone south..which is over loading the motor..
Could also be the relay on the I/O board that fires the rotate motor..it is an Omron Ice cube relay..
Old 10-18-2007, 03:31 PM
problem solved
It was a bad motor.
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
Haas Alarm Problem BMackinnon Haas Mills 24 03-13-2008 12:31 PM
Haas Indexer Alarm binzer Haas Mills 5 07-10-2007 03:11 PM
Haas alarm 165? UBRacing Haas Mills 5 07-08-2007 11:43 AM
1995 Haas VF4...Over Voltage alarm? jrudicel Haas Mills 1 02-02-2007 01:16 PM
