Old 10-16-2007, 08:04 AM
gromit68 is on a distinguished road
Haas Tl-1 Lathe no speak-a the english
Yesterdays interesting development: our TL-1 lathe lost the ability to use English.
It works just fine in Italian, French, Spanish, and German. but not English.
I called a factory tech, he believes the motherboard's battery went dead, and the machine control code was corrupted as a result. What are the odds of it being the only language I actually use?
Sweet.
By the way, Heidenhain TNC-360 controls have a nifty little feature that informs you that the backup battery has low voltage on power-up.
Apparently, the only way to resolve the problem is to have a HFO tech come out and re-install the machine control goodies.
Old 10-16-2007, 03:15 PM
serviceman's Avatar
serviceman is on a distinguished road
if the battery went dead the only memory lost should be the bbu ram battery back-up ram if the serial # of the machine is still in setting 26 then you probably did not lose the battery unless it had a bad connection if you lost the battery you would have a lot of problems you lose all your parameters settings offsets programs etc.. you do not lose the software that is flash memory. you can get the language files and load them yourself depending on the version software you have. if it is an older machine then you have to load in the software but you should be able to get that as well if you like and try to load it yourself, it is not that difficult. you need to know the software version of the machine. i may have the language files depending on the version.
Old 10-18-2007, 07:43 AM
language problem
thanks for the reply. our HFO already serviced the machine. I don't mind paying the rate for the service, but the $150 travel fee bites, as the tech lives in this town.
anyhoo...
Haas Lathe Reccomendations imwllc Haas Mills 17 04-05-2012 12:21 PM
Need help on a Haas TL-1 Toolroom Lathe tidle73 Haas Lathes 24 11-05-2008 08:49 PM
HAAS SL20 Lathe SGP Haas Mills 33 01-04-2007 04:06 PM
haas lathe post rbest27 Surfcam 1 12-22-2006 08:52 AM
Do you speak english? CNCadmin CNCzone Club House 0 05-14-2003 02:02 PM
