I'm making a list to print out as a quick reference for the most used parameters and settings that are the most commonly needed, everyone please contribute the settings and parameters that they access most frequently so I can compile a list. I'm starting with the following: Settings 51 - Door feed hold override 10 - Limit 50% rapid 7 - Parameter Lock 92 - OD ID chuck clamp 163 - .1 jog disable Parameters ? |
| 071012-0845 EST USA 1ctoolfool: A discussion of why and how you want to use this information would be helpful. Following are a few with comments: 51 ON -- disable door interlock -- immeadiately after every power on 7 ON usually -- OFF when needed -- parameter lock 9 INCH always RS232 stuff 11, 12, 13, 14, 37, 41, 55, 69, 70 -- some moderately often -- testing purposes 15 ON -- H & T code agreement -- always 23 -- 9000 edit selected as needed usually ON meaning inhibit 29 -- G91 non-modal -- never used but might be useful 31 -- reset program pointer -- would this be useful in DNC (drip feed mode) -- I have not used it 33 HAAS -- always set to this mode, on lathe FANUC mode because no HAAS mode 49 ON -- tool change -- always ON 108 -- rotary quick return 109 ZERO -- always -- I do not trust something I have no way of monitoring 143 -- interrogate machine for data while running -- useful if I were to have the function . |
| mach 3 settings | najnielkp | Viper Servo drives | 4 | 10-08-2007 06:50 PM |
| Mach3 Settings | studysession | Mach Software (ArtSoft software) | 35 | 01-08-2007 06:51 PM |
| Can someone help with Mach3 settings? | Revtech | DIY-CNC Router Table Machines | 8 | 07-23-2006 02:40 PM |
| dnc settings | jamesr | Fanuc | 1 | 02-02-2006 02:13 PM |
| Max Speed settings? | mikeschn | Xylotex | 1 | 03-27-2004 01:37 PM |
