| First, thanks to Carlos Rey (Serviceman on here, Reytech is his company) for walking me through as much of this as he has! Recap: I have a 1994 Haas VF-2 mill which we purchased an HRT-210 rotary table for. I haven't been able to get any successful use of it since it's been here. On my first attempt at connecting the unit, I got A Z CH MISSING, A MOTOR Z FAULT, and other errors indicating that there was a problem either in the cable or the encoder. I sent the motor to Oracle Encoder, where Mark found a scratched encoder disc and replaced it with what he says was an equivalent but not OEM style encoder. Reinstalled the motor in the HRT, tried again, still not working. Sent it back to Oracle where they went over it and swear up and down all is kosher. These guys have done a few motors for us and we've no reason to doubt them.With cable test on I get 'A CABLE FAULT', so I purchased a brand-new cable from Haas (NYMAT). No dice. With cable test on I'm still getting the A CABLE FAULT and the same old encoder/cable errors as before, specifically A MOTOR Z FAULT. At least A Z CH MISSING is gone. When the motor is advanced in one direction, very slowly, it will move smoothly and not error out. If moved in the other direction or quickly at all, it jumps and hops and does all kinds of crazy stuff until it simply throws the A MOTOR Z FAULT again. I've shelled out for the cable and encoder repair and now I'm no farther ahead than I was. What the heck can possibly be left? My boss is about ready to come unglued if I spend another nickel fixing this thing Help? |
| If it is specifically referring to the marker (Z) channel on the A axis, If you can monitor these signals as close as possible to the control input, you should see a high (5v) on one, usually the Z and 0v on the other /Z. This state will remain like this for almost one complete revolution, if you can turn the motor very slowly by hand while measuring the voltage they should both switch state for a very short period, once per revolution, but it it is VERY short pulse. But if it is detecting this error in a fraction of a turn then it sound like they are either both high or both low? If the voltage level checks OK, it may be the control input IC. Al.
| Ralph, Might sound like a dumb question..and maybe you have tried this..but have you tried swapping the A axis drive for one of the others to see if the error follows the drive.. This is about the first thing I normally do..to rule out the drive being the problem... Just a thought..as I'm sure you have already done this..
| 071010-1939 EST USA HAILINHAAS: Is not a 1994 machine a brush type, and if you are using the internal machine drivers, then it necessary to have a brush type rotary? Thus, my guess he has a brush type motor on the rotary or the motor would not run. Exactly when was the change to brushless DC motors? . |
In response to other questions: It's a used table, and I'm assuming my 1994 isn't a brushless machine. Also the motor/encoder seem to be the standard brush type. I don't even have an 'HRT210B' setting. Just HRT210. And Al The Man, I'm going to go check that right now. |
| Umm... My parameters end at 226 |
| Also: In order to get A to zero or home, I need to turn the parameter Z CH ONLY on, which I believe makes it not look for a home switch. Otherwise the motor just gives a quick spin and either a Following Error or a A MOTOR Z FAULT again. Once 'homed' by turning Z CH ONLY on, is when I'm able to move the axis with the jog buttons and get any movement or progress at all. Also, the suggested parameter settings of INV ENC and INV MOTOR are both '1' and the axis will only respond with anything other than following error if they are set 1,0 or 0,1. Not if both are 1. Also attaching the parameters suggested to me. A couple of the parameters listed like REV PHASING and BRUSH MOTOR are simply UNDEFINED on my machine. |
#10
| Very basic comment as I learned this while shoping for at Haas for use/adaptation on a different machine - sadly they won't. Haas was making their HRT's with brush (B) type DC motors. These used a conventional H bridge motor drive. They are making running changes to convert their HRT's from B to brushless drives - unless some fancy stuff is done, they are NOT plug and play interchangeable. Keep in mind that Haas also does a lot of soft coding of options in their controllers. If you don't pay for the option, it won't get turned on no matter if you plug in the option correctly or not. Again, basic stuff but there might be a pearl of wisdom there for the taking. |
| Fanuc 6M Encoder cable issue | Yabbos | Fanuc | 6 | 12-02-2008 07:38 AM |
| Pluto Servo Almost working Encoder Issues | TZak | LinuxCNC (formerly EMC2) | 8 | 03-15-2007 12:15 PM |
| Anyone replaced the bearings in the original steppers? | badgs750 | Bridgeport and Hardinge Mills | 9 | 01-20-2007 03:02 PM |
| $$$ for encoder cable? | murphy625 | CNCzone Club House | 6 | 03-11-2005 02:36 PM |
| Encoder Cable Question(s) | murphy625 | General Electronics Discussion | 3 | 03-06-2005 02:00 AM |
