Old 10-09-2007, 01:46 PM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
bar feed change stock diameter - help
how easy is it to change the diameter of the feed stock with the servo bar feeder?
I was told you have to move the whole bar feed and change a bushing inside the headstock but this seems silly
thanks,
joev
Old 10-09-2007, 06:06 PM
PBMW is on a distinguished road
unscrew the spindle liner and change the bushings. Raise or lower the table. Depending on size, you may have to change the pushrod.
I can have it changed in 10 min.
Old 10-09-2007, 07:19 PM
1ctoolfool's Avatar
teflon bushings
ours came with this set of 6 or 8 teflon bushings and steel tube spacers. to size the bushings they have to be machined and you have to have a set of bushings for each stock diameter, this just seems a little cumbersome.
Old 10-09-2007, 08:16 PM
big_mak is on a distinguished road
it's either change the liners, or listen to the stock rattle in your spindle!
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 10-16-2007, 02:28 PM
Gomes is on a distinguished road
Servo 300
Changing the spindle liners is easy, as long as you are using standard size bar.
We have 2 different liners and a bunch of different sized pvc pipes that go inside the liners. I would say it takes less than 10 minutes to change bar sizes (including changing the chuck jaws).
I have had some problems with the bigger spindle liner rattling around though.
We have an SL-20 with the servo 300 bar feeder http://www.ktechmanufacturing.com/turning.htm
I would say the servo 300 is a very good unit, the SL-20, not so great
2UVR Tree - Change Feed Belt jimbogrif Tree 13 08-22-2011 11:04 AM
Proper diameter drill rod or bar stock for threading? quick toy Mini Lathe 6 12-02-2007 06:34 PM
Lathe Dainichi F35 Fanuc 18TA - change diameter on radius jutek Fanuc 1 02-21-2007 03:57 PM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 09:16 PM
Is there a default feed rate ? and if so can you change it? fyffe555 TurboCNC 0 02-08-2004 08:09 PM
