Haas has the M95 command which can program the machine to sleep for a number of hours and minutes and then wake up and continue the program. Anybody using it?
| I've run some fancy Japanese things, where there was a timer that turned on to run the warm up cycle. Never an M Code.
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
From the Haas Manual: M95 Sleep Mode Sleep Sleep mode is essentially a long dwell (pause). Sleep mode can be used when the user wants the machine to begin warming itself up so it can be ready for use upon the operators arrival. The format of the M95 command is: M95 (hh:mm) The comment immediately following the M95 must contain the hours and minutes that the machine is to sleep for. For example, if the current time were 6 p.m. and the user wanted the machine to sleep until 6:30 a.m. the next day, the following command would be used: M95 (12:30) The line(s) following the M95 should be axis moves and spindle warm-up commands.
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 09:37 PM |
| paper printer machine like cnc machine ??? | patriciooholegu | Mechanical Calculations/Engineering Design | 3 | 08-07-2007 08:19 PM |
| Use Machine Shop vs. Buying Machine | imp22b | General Metalwork Discussion | 15 | 06-06-2007 06:33 AM |
| Mach 2 on old machine = great machine | foamcutter | Machines running Mach Software | 6 | 12-16-2005 12:11 PM |
| Getting work(gcode) from machine a to machine b | strat | DIY-CNC Router Table Machines | 9 | 07-07-2005 02:13 PM |
