Old 10-01-2007, 12:57 PM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
2nd home function
what is the 2nd home button, do all machines have it, and how do you use it?
Old 10-01-2007, 01:06 PM
pit202 is on a distinguished road
where is 2nd home ?
Old 10-01-2007, 03:06 PM
1ctoolfool's Avatar
2nd home button
a 2nd home button will return the machine to the position offset programmed into G129.
look on page 12 of your mill operator's manual but it doesn't say where this button is or if all machines should have it.
thanks
Old 10-01-2007, 03:22 PM
HAILINHAAS is on a distinguished road
Second home button is an option .... it would be on the left side of the pendant ... $309.00 if not
Old 10-01-2007, 04:20 PM
omy005 is on a distinguished road
We have optioned all our machine with the second home button. We Set G129 to be the opposite of X & Y machine home. It makes it very easy when cleaning the machine to jog from on limit to the other.
Andrew.
Old 10-01-2007, 11:40 PM
automizer's Avatar
automizer is on a distinguished road
the second home button is a huge help when working with the larger formate machines to set up a loading position or some other odd position you go to a lot.
I'm not lazy..., I'm efficient!
HAAS GR-408
Mirror function SWPM Surfcam 1 08-17-2007 04:04 PM
Chiron M66 function Help!!! paulu5 Fanuc 0 05-31-2006 03:48 PM
G28 Home function doesn't work TCNC 4.01 rustyolddo TurboCNC 10 07-14-2005 07:47 PM
Using the difference function ? Ken_Shea OneCNC 20 09-21-2003 06:11 AM
