Old 10-01-2007, 08:30 AM
SteJMC is on a distinguished road
Lost grub screw! - HAAS VF-4
First post, here goes;
I've got a 1998 Haas VF-4 and I've been having spindle orientation problems. I've took the covers of the headstock and it looks like the encoder pulley on the shaft end is missing a grub screw. I've got the pulley on the encoder, a toothed belt, which looks fine and then another small pulley that I can stop with my hands when I rotate the spindle. Obviously this is causing the encoder to be 'out'.
I've noticed there isn't actually a flat where the missing grub screw sits which is strange, is that normal?
Anyway, my main question is - does anyone know what size thread this grub screw will be? It looks *roughly* 3/16, not sure on the pitch/tpi.
Thanks.
Old 10-01-2007, 08:40 AM
Originally Posted by SteJMC View Post
....Anyway, my main question is - does anyone know what size thread this grub screw will be? It looks *roughly* 3/16, not sure on the pitch/tpi.
Thanks.
It will very likely be 1/4"-20 UNC. It may be 10-24 which is close to 3/16" OD.
Old 10-02-2007, 03:11 PM
HAILINHAAS is on a distinguished road
8-32 Unc
Old 10-02-2007, 03:14 PM
You Will Need To Set Parameter 254 After You Have It Tightened Down ..
Old 10-02-2007, 03:15 PM
Disregard that last one .. oops ..257 ... not 254
Old 10-06-2007, 07:16 AM
Yeah, 8-32 was the one, thanks!
Old 10-06-2007, 07:19 AM
Don't know if it's worth starting a separate thread for this, I've got a damaged waycover on this machine.
Where would I go about getting a replacement, is it a direct from Haas job?
I'm in the UK, has anybody got any ideas of prices?
Old 10-30-2007, 03:07 PM
CNCMechTech is on a distinguished road
I guess it would depend on how fast you need to be back up and running. If things arnt tight I would checdk around locally. Your best bet to get back up and running fast would be to call Haas direct or Arthur Machinery 1-800-562-2423 out of Chicago Illinois.
Old 10-30-2007, 06:44 PM
Edster is on a distinguished road
http://www.hennig-inc.com/overview.htm
Try these guys, way covers repaired fast turnaround.
I have one of their replacement way covers on the z axis of my fadal. It's great quality and about half the price of the teleflex cover.
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
