Old 09-30-2007, 07:42 PM
Vern Smith is on a distinguished road
Left hand thread with rigid tap
I need to tap some left hand threads on my TM-1P. I'm assuming there is no more to it than using M04 rather then M03? I have rigid tapping and I am also assuming it will work with M04 as well.
Vern
Old 09-30-2007, 07:59 PM
Vern
G74 Reverse Tap Canned Cycle.
Have a look inyour manual or go to the online manual on the Haas website.
For tapping, either forward or reverse, you do not need to use M03 or M04 because the controller starts the spindle. You only need to set the rpm.
Old 09-30-2007, 08:15 PM
Thanks, glad I asked.
Vern
Left hand screwcutting rcflyer Mini Lathe 10 11-07-2006 04:23 PM
I need 2 7/16"-13 left-hand-threaded nuts kdoney Employment Opportunity 8 02-11-2006 04:07 PM
Left hand cutters DAB_Design General Metalwork Discussion 6 11-03-2004 09:23 AM
coverting from Right-hand to left-hand coordinate system eltonr General CAM Discussion 6 10-14-2004 08:40 PM
Left to right leveling. ynneb DIY-CNC Router Table Machines 4 03-15-2004 08:00 AM
