Old 09-29-2007, 11:53 PM
cn00728 is on a distinguished road
MM lubrication concern
Hello,
I have a 6-mo. old MM that in the past week, is making me worry about the lubrication system. After you prime the lube system, the pressure will slowly drop to zero during operation. On the parts I ran today, I would have to re-prime it every 10 or so minutes to keep pressure up. I thought that in the past it would constantly keep pressure at 10psi or so by itself after you first prime it on power-up.... To have it constantly drop to zero though...
What is proper operation supposed to look like? Is this it?
Alex
Old 09-30-2007, 09:43 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
The lube pressure will normally bleed off ...it is supposed too..the lube pump cycles and pressurizes the lines..in the lines are restrictors..then after a while the pressure bleeds down thru the restrictors ..and this cycle of events occurs again..actually the lube pressure switch needs to cycle from "pressure to no pressure" or the machine will alarm..No need for you too.."Hand pump up " the lines..that is what the auto oiler is for...
Old 10-02-2007, 12:13 AM
automizer's Avatar
automizer is on a distinguished road
WMS is right, unless you were hand pumping due to an alarm coming up. If you are hand pumping due to an alarm your whole unit might be shot. Where I work we had a unit go and we hand pumped the thing for over a year until it got to the point where the machine wouldn't finish a 5min cycle with out alarming out. I did the change over its not to hard. Couldn't tell you the price of the replacement though.
I'm not lazy..., I'm efficient!
HAAS GR-408
Help Please? [Safety Concern] Xero Ryuu Laser Engraving & Cutting Machines 8 09-13-2007 05:37 PM
ballscrew concern project5k Benchtop Machines 14 07-12-2007 12:59 PM
Lubrication bohica Industrial Hobbies (Support forum) 17 04-29-2007 01:13 AM
Actuator weight concern WayneC Linear and Rotary Motion 3 09-29-2006 10:34 AM
Concern with gantry lift CuttersCov DIY-CNC Router Table Machines 11 02-18-2006 07:30 AM
