Old 09-29-2007, 04:30 PM
big_mak is on a distinguished road
Talking Haas Control and Vacuum Chuck
I'm looking to use a vacuum chuck for some of the prod. parts we are making.
What I want to know is can I use a Vacuum gage to trigger an alarm condition, when the Vacuum is lost to a certain point?
I know some one who's rigged this type of system up on some fancy pants japanese machines.
Possible to do with Haas????
I also want to know if I can adjust the airblast time during the tool change. I'd like to be just a bit longer to make sure the taper is getting flushed just right!!
TY
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 09-29-2007, 09:37 PM
samhyto is on a distinguished road
The easiest way would be to wire it into the door safety circuit. That way the machine would respond just like a door was opened. You'll want to run a switch in parallel with your sensor, that way you can switch it to a bypass mode when you aren't using the vacuum system.
Sam
Old 09-30-2007, 06:57 PM
The easy way to do it is with the door switch circuit and set the Door Stop Spindle Parameter to 1 so that both the Feed and Spindle stop if you lose vacuum. Then remember you must not run with the Door Hold Override on.
Old 10-01-2007, 01:25 PM
Thanks Guys,
My spindle will thank you profusely
Haas TM-2 control question Zeekh Haas Mills 1 03-14-2007 09:14 PM
haas servo control heartlnd Haas Mills 0 02-10-2007 06:04 PM
haas rotary control heartlnd Haas Mills 0 02-04-2007 02:46 AM
Haas TM-2 Mill Control Malish Fanuc 1 06-26-2006 09:54 PM
Can CNC control the lathe chuck? Big Noodles Shopmaster/Shoptask 8 03-05-2006 04:49 PM
