Old 09-27-2007, 06:25 PM
Donerb is on a distinguished road
haas chip sweeper
I saw an ad for a chip sweeper that you add to your Haas VF series mills that is driven by the chip auger a while back. Of course now I can't seem to find any info on it now that I want to get one. Anyone out there know who makes them?
Old 09-27-2007, 06:47 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
us shop tools.... google them..
Old 10-09-2007, 06:56 PM
cjablonski is on a distinguished road
Notes
I recently purchased one and noted several items. It is made for an older Haas with round drain holes drilled in the sheet metal and you just have to drill holes in the removable drain screen and countersink 2 of the screws so the wipers clear. After a short time I noticed the filter screen inside the tank was frequently becoming clogged with small chips. Since the wipers are spring loaded it appears that besides sweeping the drain screen they were also pushing small chips through it. I solved this by adding a spacer to remove the downward pressure of the wipers so it just sweeps the chips into the auger. In my case the drain was just being covered and not clogged, so you need to look at that based on the chip type and material.
http://www.usshoptools.com/current_y...GS_557_559.pdf it's on page 559
Hope that helps.
Old 10-10-2007, 12:03 AM
Hey thanks. I was going to a unit using brushes after seeing something very simular on a conveyor once. Someone told me about the shop tools unit and I was surprised to see how much alike they were in principal. I am using a screen under the removeable oval plate now and this does a pretty good job of keeping the chips out of the tank. It does however keep you scrapping it off after a couple parts too make sure the coolant does not back up.
Chip to Chip Time Gene0552 General Metalwork Discussion 36 09-01-2010 11:05 AM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
How to not be Chip sweeper? DareBee Forum Questions or Problems 18 07-03-2007 09:03 AM
chip sweeper scappini CNCzone Club House 11 08-01-2006 05:07 AM
