Just taken delivery of new haas tm 3, been on the course and dont have any problem drilling etc . We could do with an example programme for a slot between two centres say at start position x10 and end position x100 and 12mm deep using 1mm cuts . I think we need to call a sub programme up but we have no idea how to do this , once we get the right format we can use this for numerous applications . Any help greatly appreciated. |
| The M97 Pn calls a subroutine which is tacked on after the M30 in the program and starts with line number n: O00000 Stuff M97 P1000 Stuff M30 N1000 Subroutine Stuff M99 The M99 returns the machine back to the line below the M97 line...Except if you have this: O00000 Stuff M97 P1000 Ln Stuff M30 N1000 Subroutine Stuff M99 Now it returns to the M97 line until the L is counted down to zero so you call the subroutines n times. You can also have a motion command on the M97 line like this: G91 G01 X90. Z-1.0 Fwhatever M97 P1000 For slotting I place the tool just above the surface at one end and offset negative by half the difference between the tool width and the slot width. Then I use a line like the one above, the tool increments the length of the slot going down the Z distance and then enters the subroutine. In the subroutine the tool increments positive the difference between tool and slot width, then increments negative the X distance and then negative the slot/tool width difference so it is back where it started for the M99. This sequence repeats n times at which point the tool has reached the final slot depth but part of the slot still has the final Z increment. On the last return the machine goes to the line below the M97 with the L count and this is also a M97 command so the subroutine is run through one more time without any Z motion; This takes out the ramp from the final Z increment. It is also possible to have an L2 so that there is a springpass to remove tool deflection. After the second M97 there is a G90 G00 Z1.0 to go back to absolute and lift the Z clear. Using Tool Compensation requires a few extra commands and sometimes it is necessary to start at the center of the slot to avoid overshooting the end on the final motion command before the Z retract and the G40 move. If you write a few sample programs and look at them in graphics you will se what I mean.
| Slotting MDF | Me2 | General Material Machining Solutions | 2 | 07-27-2007 11:25 PM |
| plc programme | mohd khalid | PIC Programing / Design | 1 | 05-07-2007 03:36 PM |
| Slotting for CNC | Kavanthony | General Metal Working Machines | 3 | 04-04-2007 04:20 AM |
| Slotting 1095 | tr4252 | General Metalwork Discussion | 2 | 09-28-2006 06:59 AM |
| deep slotting in aluminum | flymach1 | General Metalwork Discussion | 15 | 04-29-2006 12:42 PM |
