Ok. I've used Haas rotarys that were hooked to the control as a true 4th axis. I've got a question about using a Haas rotary with the control box and M-codes. I can only run 1 program with 1 m-code right? Each program can have 99 steps. I only have 1 m-code hooked up, so will each successive call of the m-code activate 1 of the steps of the program? Call m181 once and step 1 of program in box is executed. Call m181 again and step 2 of program is executed. Is this correct? Thanks in advance. |
| Parameter 10? I should have specified that I'm running this rotary table on an Okuma MCV4020 and a Fadal VMC15. Is parameter 10 in the Haas control box or in the Haas VMC? WMS, I've used OneCNC for programming my TM-1 with the rotary table controled through the machines control as a true 4th and it's worked perfect with the stock Haas post processor. Is there any way to have OneCNC output the 4th axis codes as an m code with the acutal move as a comment so I can easily program the rotary. Example M181 (step 1: A180. F20) or something like that. Btw, I'm just using this as an indexer. |
| Ed, I'm headed out the door for the day..but I'll post something up this evening when I get back..it can be done..well as you out it "something like that"..
| Edster, What Serviceman is talking about is parameter #10 in the Haas axis control box.. If set to "0" , it stops after each step,(IE: M code) and waits until next M code to index again to next step.. This would be the default setting..but you can change it to step clear thru the program with one M code..or a couple of other settings..it is all in the manual.. Anyhow ...I dropped a post on the OneCNC forum > Tips and Tricks section about how to set your post up for a stand alone control box like you are asking..Figured it was software question and not a Haas question per say.. Plus that way it is there for other users to see..
| Question on Rotary Table | zwdeal | Benchtop Machines | 20 | 06-05-2007 11:12 PM |
| Rotary Table Question | Cory | Haas Mills | 13 | 12-13-2006 07:43 AM |
| and another rotary table question. | hangslot | Haas Mills | 3 | 11-26-2006 01:41 PM |
| Another Rotary table Question | archer66 | Haas Mills | 8 | 11-10-2006 11:32 AM |
| Programming a rotary table | Nigel_B | Mach Software (ArtSoft software) | 2 | 09-16-2006 09:17 AM |
