Old 09-15-2007, 11:36 AM
chakaloso is on a distinguished road
Feed rate and Speedle speed for M4-.7 tap
I have to mini mill, and I have to make some metric taps. I am not sure how to get the feed rate and speed for taps in metric.
I know in standard taps just multiply the treads per inch by the feed rate. for example. 4-40 tap. feed rate 5.0 speed 200.
Any help thank you
Old 09-15-2007, 11:46 AM
Webderland is on a distinguished road
25.4
Old 09-15-2007, 11:50 AM
pit202 is on a distinguished road
just how you described it , a normal M4 has 0.7mm pitch(?) so :
Feed rate = spindle speed * pitch
eg. 1000RPM * 0.7pitch = 700mm/min
Old 09-15-2007, 12:20 PM
convert
There are 25.4mm to 1 inch, so it's easy to convert any millimeter size to inches by dividing it by 25.4 or multiplying by 0.0394.
Old 09-15-2007, 12:40 PM
Ok
for M4-0.7
I can use feed rate:2.756 in/min and speed: 100 rev./min
Old 09-15-2007, 12:54 PM
Originally Posted by chakaloso View Post
Ok
for M4-0.7
Do not run the spindle this slow; it will not keep the correct synchronization with the feed.
Run at 1000 rpm and use a feed of 27.559 IPM
You could even run at a higher speed if you want to.
Old 09-15-2007, 01:00 PM
Thank you for the info.
I will run the part in a few minutes and let you know.
Old 09-15-2007, 02:50 PM
Smile
It works
Thank You!
Old 09-20-2007, 03:38 PM
Jason812 is on a distinguished road
I don't know how many you you are as anal as me with the decimal places in feed rates but if you use a spindle speed with a multiple of 127rpm then the feed rates for all metric taps will come out to a "nice" number.
Pitch in inches = metric pitch/25.4
tpi for M4 x .7 = .7/25.4 == .0275590551 * 127 rpm = 3.5 ipm
multiply by 8 == 1016 rpm and 28.0 ipm
I've made a calculator in Excel to make this quick and easy.
Hope somebody can use this,
Jason
Old 09-20-2007, 03:52 PM
Originally Posted by Jason812 View Post
.....if you use a spindle speed with a multiple of 127rpm then the feed rates for all metric taps will come out to a "nice" number.....
But then you get a 'nasty' spindle speed .
It is a neat calculation, however, that harkens back to the manual change gear days with the 127 tooth gear for cutting metric on an imperial lathe.
surface speed and feed rate calculator derkiow General Metalwork Discussion 9 06-04-2006 07:33 PM
Feed Rate? bearwen GRZ Software- MeshCAM 3 04-26-2006 04:52 PM
Spindle speed & feed rate on a Taig Stuff-Builder Taig Mills & Lathes 5 08-29-2005 05:01 PM
C & Z Feed rate rfstar G-Code Programing 7 06-22-2005 12:38 AM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 09:40 PM
