Old 09-13-2007, 01:33 PM
JMFabrications is on a distinguished road
304 Stainless recommendations
Can anyone recommend a good roughing end mill for 304 SS. I am cutting some stainless exhaust flanges on my VF2 and breaking bits left and right. Currently im using these cheap eBay "so-called" carbide finish/rougher combo end mills im assuming I get what I pay for. Here are the specs:
3/8" thick 304 SS
1/2" em
.1875 DOC slotting (2 passes)
100 SFM
.0015 chip load
5 IPM
764 RPM
Id like to be able to move faster, an hour for 3 exhaust flanges isnt gonna cut it! I dont mind doing a roughing pass first then go over it with a finish em. Let me know what kind of recommendations you guys have for me.
Thanks for your time!
Jim
Old 09-13-2007, 02:39 PM
tcampbell is on a distinguished road
I use tialn coated endmills for stainless. I would rough out with a rougher and then finish it. You may be able to get away with just a regular endmill that is tialn coated. SS take time to cut.
Old 09-13-2007, 03:19 PM
jorgehrr's Avatar
jorgehrr is on a distinguished road
I went trough something like that when we change 303SS and went to
304SS couldn't drill two holes with out breaking drills.
I nice drill from kennametal with coolant trough did the job.
DFR0703RSSF075
Can drill @ 2000rpm F.008 (yeap couldn't believe it myself)
Try calling them, they will hook you up with the right end mill.
Cheers
Jorge
Old 09-13-2007, 03:44 PM
big_mak is on a distinguished road
Look at some HSSCo roughers from niagara. They should do the trick in one pass, then come back and clean it up with a Solid Carbide 4-5 flute with TialN coating!!!!
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 09-13-2007, 04:24 PM
Ive been using a lot of Nigara's end mills for aluminum and they work great. How well will cobalt roughers hold up in SS? Im all for roughing in one pass! Im using cobalt drills now and they seem to work well in SS.
Old 09-13-2007, 04:31 PM
PBMW is on a distinguished road
You are slotting...are you drilling an entry hole for the EM?
I machine LOTS of 304ss. 350sfm and .0035 per flute. I would do the slots full depth as you put more cutter on the material and don't wear out the corners.
Old 09-13-2007, 04:32 PM
If you get the speeds and feeds dialed in, you'll be alright. I prefer the fine pitch roughers myself!!!
Good Luck!
Old 09-13-2007, 04:35 PM
PBMW,
wut cutters r u using? SC I presume
Old 09-13-2007, 04:40 PM
Yes....im drilling a start hole for the em. Are you using carbide or cobalt for those speeds?
Old 09-13-2007, 05:25 PM
Carbide. I get them through Carbide Connections. Three flute with a .03 corner rad. It's a DataFlute copy
  #11   Ban this user!
Old 09-13-2007, 06:36 PM
So if my math is correct thats about 2674 RPM and 28 IPM....thats some aggressive machining!!!
Do you prefer 3 fl over 4 fl for SS?
Thanks for all the help!
  #12   Ban this user!
Old 09-13-2007, 09:55 PM
AMCTony is on a distinguished road
Call Kennametal. Its gooooood.
Need some recommendations DragnsBane General Electronics Discussion 4 01-31-2007 03:11 PM
VFD recommendations? split63 General Metal Working Machines 13 05-27-2006 04:39 AM
CNC Engraving Recommendations ikekrull General Metal Working Machines 3 02-02-2006 07:51 PM
TIG recommendations? nervis1 Welding, Brazing, Soldering, Sealing 40 04-17-2005 12:50 AM
CAM Recommendations Benjamin General CAM Discussion 3 09-07-2003 10:32 PM
