Old 09-01-2007, 11:05 AM
hutch07 is on a distinguished road
Arrow Haas VF-2 tool changer alignment.
Does anyone know a fool proof procedure to insure the tool changer is aligned well. Parameters, heights, debug???
Old 09-01-2007, 01:24 PM
serviceman's Avatar
serviceman is on a distinguished road
depends on what you want to align. parameter 257 is the spindle orient parameter if you have a vector drive. parameter 64 is the tool cahnge height but if you have to change that you might want to look at your plate to see if is bent or your v roller bolts are bent or loose. then there is the casting bolts that adjust the leftr to right movement.
Old 09-03-2007, 09:27 AM
Thanks it was the tool change height
Thanks serviceman.
I adjusted both the orientation and the tool change height. I did not know how to change the settings "Go to setting #7 and turn protect off". After that We got it. I think we may have one tool bent down.
Thanks for the quick response.
Hutch
Haas TM1 tool Changer by Gifu DJPdesign Haas Mills 12 05-27-2007 09:15 AM
tool carousel alignment rubino2112 Machine Problems, Solutions , Wireless DNC, serial port 0 12-27-2006 12:26 PM
tool changer problem on haas mini mill Greg 24 Haas Mills 2 03-05-2006 02:20 PM
Haas mini mill tool changer sliding covers? duenow Haas Mills 6 07-18-2005 11:46 AM
Haas vf3 ss side mount tool changer MBFisher General Metal Working Machines 1 02-28-2005 08:23 AM
