Old 09-01-2007, 11:03 AM
hutch07 is on a distinguished road
Arrow VF-2 Tool changer
We have been having random tool changer issues with our 1999 VF-2 The tool changer thinks it has changed the tool but does not move. It brings the wrong tool into the part and CRASH things go bad.
Can someone point me in the right direction this weekend? I have to get this thing going. We have replaced the switches on the changer.
Help
Old 09-01-2007, 02:33 PM
HaasTech83 is on a distinguished road
Do you get any alarms? If you look at current commands page, does it say the right tool is in the spindle?
Old 09-01-2007, 08:26 PM
AMCTony is on a distinguished road
If this is not a program that you run before I would check that as well.
Old 09-04-2007, 09:42 AM
GITRDUN is on a distinguished road
If its not even atempting to change the tool i would think there is a problem in the codeing or something.
Old 09-04-2007, 07:52 PM
Talking Geovena Switch
Thanks a bunch to all that have posted for the pointers . It turns out that the switch that looks at the geoneva mechinism had a break in it. It was actually counting twice once in a while. We replaced the cable, used setting 7 to turn off the parameter protection and reset the tool change position and spindle orientation just for good measure. Then we went on to the switch. We swapped switches with the #1 tool switch and the problem stayed. We rewired [hotwired] the geoneva switch and that worked. We made it better by routing the cable through the top of the box. It looks much better and puts less stress on the wire.
Thanks Again!
Tool changes without a changer on TM-1 mpstech Haas Mills 18 01-11-2007 01:20 AM
tool changer motomitch1 Fanuc 6 08-10-2006 03:02 AM
Tool Changer Moondog Mach Software (ArtSoft software) 4 05-21-2006 02:34 PM
Automatic tool changer bunalmis Mechanical Calculations/Engineering Design 3 02-04-2006 03:57 PM
Tool Changer - How? creative_mind CNCzone Club House 17 08-30-2003 10:01 PM
