Old 08-21-2007, 05:59 PM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
coolant in oil separator
im getting my oil separator tank overflowing with coolant, this just started happening a few hours ago, please advise, thanks
joev
Old 08-21-2007, 06:06 PM
We have had this happen. The thing the oil/coolant flows out of gets gummed up with sludge on the inside so it does not separate the oil from the coolant like it should.
You can take it off by undoing the ferrule nut at the back. Then take the front off and wash everything out with degreaser and put it back together. It should work okay then.
Make sure it is sitting level when you put it back.
Looking for a better coolant? shawn General Metalwork Discussion 9 06-29-2009 10:13 AM
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 08:02 AM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 01:20 AM
DHZ Series Disc Separator fire4427zlm Product Announcements & Manufacturer News 0 02-09-2007 07:35 PM
COOLANT (what are you using?) carbidecraters General Metalwork Discussion 12 01-22-2006 12:31 AM
