Old 08-19-2007, 02:53 AM
skydivebase is on a distinguished road
How Long/RPM
Just started running some 3d parts for the first time. I'm beginning to realize the lengthy machine times involved.
Q. How long would you be prepared to run your machine at high RPM s. We have a VF1 with a 10K spindle.
J
Old 08-19-2007, 09:32 AM
J
This question was asked in the "Answer Man" page in the Haas CNC magazine. You could probably find the answer if you went to www.Haascnc.com and found the back copies of the machine but I recall that the answer was; up to 100% load...indefinitely, 120% load...30 minutes; 150% load...10 minutes.
Old 08-19-2007, 09:53 AM
PBMW is on a distinguished road
That would be duty cycle. I think he's asking about how long is it permissable to run at max RPM.
My rule of thumb is, I warm my spindles in the morning nad then put them to work. If you properly warm the spindle, and there is a noce warm up program on the Haas site, you should be able to run max speed all day. I run my mills at or near max rpm all day (12 to 18 hours a day) 7 days a week. No issues. But I DO properly warm them up.
I do a lot of 3d machining. some of those programs can run 30 hrs or more...
I've not had a problem.
Old 08-19-2007, 09:59 AM
Originally Posted by PBMW View Post
That would be duty cycle. I think he's asking about how long is it permissable to run at max RPM.....
Yes I did not explicitly say this was for full rpm on a 10k spindle.
Your point about warming up is very important. I have a couple of 15k machines which get warmed up morning and late afternoon on the days that they are not in use. I learnt the lesson one time when the warm up cycle was run after a ten day period and the spindle finished up too hot to touch.
Old 08-19-2007, 06:03 PM
Cool
Yes I was more concerned about max RPM more than Load.
Thanks for your input.
Can someone post the warm up program/post the link.
J
Old 08-19-2007, 08:29 PM
Found it
I got the warm up program from the Haas site.
J
How long should an end mill bit last? MagTDK DIY-CNC Router Table Machines 11 04-27-2007 02:30 AM
How long does it take? phantomcow2 Stepper Motors and Drives 5 03-15-2007 02:46 PM
How much is too long? monte55 Xylotex 3 11-30-2006 09:48 AM
How long does it take CNCadmin Steam Engines 4 11-08-2006 10:45 PM
Not long now CRFultz DIY-CNC Router Table Machines 9 01-11-2005 02:13 PM
