Old 08-14-2007, 12:39 PM
lovell110 is on a distinguished road
axis overcurrent
I searched this forum for some info but I did not find anything useful. So I apologize if this question is redundant.
I have a VF2 that gave me a Z axis overcurrent alarm. I shut down and cleaned out the brushes and tried again. Same thing! I swapped the Y axis and the Z axis boards and the problem moved to the Y axis. Now my question is before I go and call HFO for a replacement board has anyone gone any deeper in finding the problem on the board? I already checked the fuses on the board and now I am moving to the resistors. Any guidence would be appreciated.
John
Old 08-15-2007, 01:03 PM
serviceman's Avatar
serviceman is on a distinguished road
you can replace the fets which are usually blown relatively cheap you can ohm them out and see the blown ones they are the 4 discs on the rear part of the board on the heat sink.
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 07:31 AM
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 9 08-17-2007 10:11 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
VF-2 overcurrent on Y axis coalstove Haas Mills 4 08-03-2006 03:32 PM
alarm! spindle overcurrent jianjianca Bridgeport and Hardinge Mills 2 04-26-2006 11:35 PM
