#13
Pretty much the same as all the Haas machines...control wise.. I do see a "RS232 Abort" sometimes..but I just resend the program and all is well... And if you get that message you need to check the alarm message page for the exact alarm number..usually a rs232 break..and most often it is just noise. Or a time out. A resend and you are go to go..well here any way..
#14
Pretty much the same as all the Haas machines...control wise.. I do see an "RS232 Abort" sometimes..but I just resend the program and all is well... And if you get that message you need to check the alarm message page for the exact alarm number..usually a rs232 break..and most often it is just noise. Or a time out. A resend and you are go to go..well here any way..
#15
| 070808-2057 EST USA wms: I do not believe there is ever a timeout on HAAS. This can be proven by sending a file without the trailing % and HAAS will, I believe, wait forever for more data. If while HAAS is waiting you send another and different O-number without the leading % this different program will be loaded. Also there is no timeout waiting for you to send a file. This is a great asset compared to other machines. I also believe you can send any junk before the first % or any after the end % without an error. This excludes some newer capability where HAAS can receive external data into a running program. . |
#16
I need to check the available memory, however I have been traveling so I haven't had a chance. |
#17
#18
| I had the same problem today. I spent an hour trying everything I could think of. The control would accept some programs, but not the program I was trying to send. I couldn't see anything different but for the hell of it, I changed the program number and wallah...it worked. I've run Haas machines for 19 years and this was a first for me. So if you're having the same problem try changing the program number and let us know if you got the same result. |
| RS232 Help | Jerrytool | Daewoo/Doosan | 9 | 03-15-2007 05:51 PM |
| USB to RS232? | Klox | Computers and Networking | 7 | 11-29-2006 02:11 PM |
| RS232 & other things | alwayslearning | General Metal Working Machines | 4 | 07-25-2005 07:12 PM |
| RS232 communications | cobrav18 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 07-07-2005 12:46 PM |
| Mach2/3 and RS232 | jderou | Mach Software (ArtSoft software) | 2 | 05-28-2005 07:10 AM |
