Old 07-26-2007, 09:41 PM
Cory is on a distinguished road
Spindle Hot To Touch
I'm running a brand new VF-1. 10k RPM with gearbox.
It's total runtime is probably under 20-30 hours. No more than 40 tops.
I've been running it almost continually for the last 5 hours. Cutting 6061 aluminum. Mainly 1/2" ball and flat endmills, moderate DOC at 7500-10K rpm, from 60-90 IPM.
Stopping between parts, it felt noticeably hotter inside the machine enclosure than out. I felt the spindle, and it feels like it's around 85-90*F. Definitely hot to the touch.
I can't imagine this is normal, however I figured maybe running it at 10k for the last 5 hours might have something to do with it?
anyone have any input?
Thanks,
Cory
Old 07-26-2007, 10:27 PM
HuFlungDung's Avatar
Moderator
Are you allowing some flow of coolant out the fitting on the bottom of the head, or is it all going through the programmable coolant?
Old 07-26-2007, 10:29 PM
We don't have programmable coolant.
Old 07-26-2007, 10:35 PM
85 to 90 F is not that hot. Are you able to hold your hand against the spindle for a very long time? If you do not have to pull your hand of because it is to hot for comfort then it really qualifies as warm . Which might seem a picky point but I have had several spindle feel distinctly warm to the touch after running long cycles at 10,000rpm.
I have also had hot spindles, much to hot to comfortably hold a hand against, and these were caused by running the machine at high speed after it had been sitting for a couple of weeks without being used.
The cure for this is to run the Haas Run In program with the spindle lube air purge turned up to 30 psi to purge accumulated oil out of the lower spindle bearing.
I suggest you simply run the Run In program and when it is cycling through the higher speeds open the door occasionally and feel the spindle. If it is too hot to touch turn the machine off, let it cool down and then restart Run In. This procedure was suggested to me by one of the Haas engineers when I sent an email about a very hot 15000rpm spindle. I had to turn the air pressure up and do the Run In twice before the machine could operate at full speed without getting hot.
We have found that on the 10000 rpm spindles it is a good idea to run the Warm Up program every morning and if the machine is idle run it again just before quitting time.
Old 07-26-2007, 10:37 PM
Moderator
Ok, so does that mean you have coolant flowing out the bottom fitting on the head casting? I've not seen one without Pcool to know if they have just a big pipe off to the side or what.
Old 07-26-2007, 10:46 PM
The coolant does not flow onto the head casting.
Thanks Geof, that's what I was looking for.
The machine had been sitting for about a week. I ran the warm up program prior to use. Are you referring to the warmup program, or the run-in program? I run the warm up program quite often.
The spindle is only warm by your definition. I could hold my hand to it for an extended length of time, without experiencing discomfort.
The only real reason I was concerned was because the Haas tech mentioned during the initial setup that the spindle had some excess vibration. It still seems like it makes what I'd qualify as a fairly awful noise at high RPM's, compared to other Haas mills I've heard running. I plan on having them come out to take a look-see, but I wanted to make sure I wasn't going to destroy my machine in the meantime
Old 07-26-2007, 11:03 PM
Do the Run In program as I suggest while checking the temperature.
Regarding your excessive vibration I have a Super MiniMil which had a horrible vibration at certain speeds. The local Haas tech did a vibration analysis three times, sent the data to Haas and everything checked out okay so I just let it run. Then we started doing a job which needed a lot of material remove so we were pushing the machine hard; it made an atrocious noise. It was well out of warranty so I started pulling covers off to see if I could locate the source. It was the spindle sheet metal vibrating and hitting a ridge on the casting; you could see the shiny polished metal. The ridge seemed like something left over from the casting so I used a grinder to take a bout a sixteenth off...bingo quiet machine.
Incidentally are you using balanced tooling? 10000rpm is borderline for balanced tooling; you can get away with using non-balanced holders but at full speed the machine might make a lot of noise.
Old 07-26-2007, 11:07 PM
I'm using Rego-Fix ER-32 collet holders which are supposedly balanced to 22,000 RPMs.
The machine just doesn't quite sound right at all RPMs. It just becomes more noticeable as you get above 6000 RPM or so. It gets better as it runs longer (or maybe my ears just become more accustomed to it).
Old 07-26-2007, 11:12 PM
axis is on a distinguished road
if the tech thinks that somthing didnt sound right get on
get it tested
there will be some extra noise with the gearbox but if your not sure ask haas
vibrations will kill you machine and it is not cheap to fix if your out of warrenty
Old 07-26-2007, 11:33 PM
I have a feeling for what you mean. Definitely the noise varies with speed which I think is a resonance and definitely your ears are not a reliable detector because they do habituate.
All you can do is get the tech in to check it out; if the machine is under warranty this is what they should do whenever you ask. Although maybe I have a bit of extra clout with my Haas dealer having bought seventeen machines and asked for a quote on number eighteen today.
I mentioned the Super Mini that was noisy; I have a new VF2 that is still under warranty and some mornings it makes a really funny noise during Warm Up. It seems to be temperature dependent and does not happen every day. My plan is to monitor it very closely when the machine is about two months away from the end of the warranty and if it is still doing it get the dealer in to start looking at things.
  #11   Ban this user!
Old 07-27-2007, 12:08 PM
serviceman's Avatar
serviceman is on a distinguished road
150 degrees f on the inside of the taper is the cutoff then haas says that spindle is hot. if the machine is under warranty then you should just run it till it dies run it overnight at max rpm if you come in the morning and the spindle is seized then you get a new one. then they will have to verify oil flow and make sure everything is good on the new spindle
  #12   Ban this user!
Old 07-27-2007, 12:21 PM
Originally Posted by serviceman View Post
150 degrees f on the inside of the taper is the cutoff then haas says that spindle is hot....
This is 65 degrees C and is hot enough that you can touch it for a short period of time but it will not burn you; that is the type of temperature I was meaning in my first post.
I am not sure I agree with serviceman's advise. Yes, you might learn that the spindle can run overnight without problems, or you might learn that it cannot. Coming in next morning to a pile of smoking scrap is not very helpful toward diagnosing the underlying problem.
touch probe and Mach3 devincox Mach Mill 13 02-15-2010 09:58 PM
Z axis touch probe Swede FlashCut CNC 7 08-29-2007 01:09 PM
Touch probe for sale cut more Digitizing and Laser Digitizing 2 03-08-2007 06:50 AM
anyone use a touch screen? jderou Screen Layouts, Post Processors & Misc 13 09-01-2005 07:09 PM
homemade 3D touch probe? cnczane DIY-CNC Router Table Machines 26 06-26-2004 08:17 AM
