#49
| 070812-1150 EST USA Thanks Geof for filling in information I am not familar with. My reason for suggesting this be in a different thread is because it would be useful for someone starting without any prior background. It might be titled "Starting to work with a HAAS". When first starting there are some necessary decisions like --- HAAS, Fanuc, and Yasnac mode, setting 58, etc. Inch, metric setting 9. 81 Tool At Power Up. 83 M30 Resets Override. This is just a sampling. . |
#50
. It could be very useful.
#53
| 070812-1651 EST USA Geof: I am thinking about your comment. timmydabull: What specifically did Geof or I say that solved your problem? I am going to suggest that you set up for HAAS mode, setting 58. You do this by going to the SETTINGS page, then to setting 58, right cursor to HAAS, and push WRITE. In HAAS mode if you are not doing anything with G52 put this line of code in every program before any motions: G52 X0 Y0 Z0 When you get more comfortable with HAAS I will make some comments on how you might use G52. When you write a program on your computer it must start off with % Oxxx (a comment to tell you what this program all about) your program initialization stuff your program code % You have to start with a %. The Oxxx is you program number that is used internal to HAAS. Oxxx can have 1 to 5 decmial digits for xxx on newer machines. Older machines are limited to 4 digits. Comments must always be delimited by a left and right paren ( parenthesis), and there is a maximum limit between parens or maybe it is a line length limit. You must always have an ending %. When you load a program HAAS does not start the load until the line after the first (start) percent. It loads eveything until the next (ending) percent unless there is an error. It will wait forever without the ending percent. . |
#56
| Hey guys just wanted to come back and give an update on my progress with the new machine. after 3 or 4 weeks of working with the machine i have gotten familiar enough to set tool offsets setup workpiece offsets and hand program some g code,even run a small batch of parts. i wanted to personally thank all of you who have helped,your advice and the wealth of information on this site has been very helpful. i am very greatful for your help. thank you now its time to start working with cad/cam cheers |
#58
That sounds about right; it took me six weeks from getting a HL1 to actually getting a finished part off the machine. I had never done anything with CNC before. In my opinion you should spend about another six months or more polishing your G code skills then start doing CAM
| Newbie- what do I need? | davidflana | Commercial CNC Wood Routers | 8 | 01-08-2007 04:18 PM |
| Newbie to CNC: considering X3 | themaddhatter | Syil Products | 2 | 12-05-2006 08:43 PM |
| Help a Newbie? | ogre_underkill | Commercial CNC Wood Routers | 1 | 07-17-2005 12:38 PM |
| Help for newbie? | RBinAR | Mini Lathe | 7 | 11-17-2004 03:29 PM |
| Newbie Needs help! | gmarquez04 | General Electronics Discussion | 4 | 10-26-2004 07:05 PM |
