Old 07-18-2007, 09:41 PM
HuFlungDung's Avatar
Moderator
Oil seepage from Haas rotary
Is it normal to have a bit of oil weeping out of the front seal of something like the HRT310 rotary? I use it a lot running unclamped while doing spiral milling, and run it for an entire day. It leaks enough that would saturate 4 ordinary paper towels, a few tablespoons, I suppose.
I'm supposing that this might be normal, due to running unclamped (maybe creates a bit of clearance, or something) but I don't know if a brand new one would behave this way. I bought mine used, in apparently excellent condition, but with an unknown amount of hours on it. I wonder if there is a worn seal or one that has 'gone hard' and should be replaced.
It does not leak when sitting unused.
Old 07-18-2007, 10:02 PM
Does it get warm while it is running? This could act to push oil out through the seal. Something the diameter of the seal on a 310 can be expected I think to show a bit of weeping; calculate how much it is losing per inch of seal length per rotation and I bet it is a very tiny number. I know if I was encountering a few paper towels full per day I would make sure I had a supply of oil to top it up and not do anything else. If it was leaking anything overnight while not running then I would look into it.
Old 07-19-2007, 12:33 PM
Moderator
Thanks for the reply, Geof.
The unit is stone cold, as it is turning very slowly.
I did get a pail of oil, so I suppose it seems suitable to keep sopping up what seeps.
Old 07-19-2007, 01:37 PM
Edster is on a distinguished road
I have a HRT160B new in 06. Never leaked a drop running or sitting. Are you using the Haas oil?
Old 07-24-2007, 11:31 AM
binzer is on a distinguished road
I just changed the oil on a 210 its been running for 2 years and never leaked a drop oF oil. But The other day air was leaking out the back. So order the 2 diffrent o rings pulled the cover and there was a lot of rust. The bigger O ring was the one where it was leaking but the o ring looked fine I replaced it anyway and everything is fine now.
haas rotary heartlnd Haas Mills 1 04-27-2007 07:43 AM
I need MasterCamX Post for Haas VF4 + HA5C Rotary didwat Laser Engraving & Cutting Machines 0 03-04-2007 12:13 AM
haas rotary control heartlnd Haas Mills 0 02-04-2007 03:46 AM
HAAS Rotary - Can I make Yuasa work? 1ctoolfool Haas Mills 3 08-10-2006 01:17 PM
Haas Rotary History ARB Haas Mills 4 01-13-2005 02:02 PM
