Old 07-17-2007, 09:23 AM
JMFabrications is on a distinguished road
Where to specify edge finder diameter?
Sorry for all the newb questions, I just got a VF2 and its a big step up from my old Acer knee mill with centroid controls. On my old machine it had field to specify the diameter of the edge finder being used, I cant seem to find that on the HAAS and my first part was off....maybe im not looking hard enough or do I just have to do it manually........?
Thanks,
Jim
Old 07-17-2007, 10:27 AM
M30 M30 is offline
M30 is on a distinguished road
I have a HAAS TM-1, and I don't think there is any place for it to compensate for the diameter automatically. I always just subtract half the diameter in my work offsets manually - which is actually adding as all the offsets are negative. (i.e. a .2" diameter and X at -17.2342 would end up being -17.1342)
Maybe someone else here can show me a trick I did not know to compensate automatically.
Old 07-17-2007, 05:53 PM
jprobst is on a distinguished road
I have a vf-2 and from what i know that is not possible on this machine, or i just don't know it yet. I use a .2" dia. edgefinder and i hit the part zero button then i add or subtract .1" from the number. hope that helps
Old 07-18-2007, 09:10 AM
I ended up just entering it manually, no biggie....I was just used to the other way. Thanks for the input!
-Jim
Old 07-18-2007, 11:07 AM
M30 M30 is offline
You can put in the diameter of finder in the tool offsets. I was going to play around with the different tool compensation codes to see if I could get it to compensate for the radius when jogging.
Has anyone tried that?
Old 07-18-2007, 07:32 PM
Im still trying to get familar with this HAAS display....is there anywhere that tells you the cut time for the current part you are machining, as well as the number of completed parts. I did see some timers in there but they are all displaying total numbers from when the machine was put into operation.
Old 07-18-2007, 09:11 PM
HuFlungDung's Avatar
Moderator
Jim,
When you are looking at the "time" screen, you can cursor down and zero some of those with the origin key.
Old 07-19-2007, 01:04 AM
Originally Posted by HuFlungDung View Post
Jim,
Worked great....thanks for the tip! Im almost ready to put the manual away...its been by my side for the past week!
Question About Edge Finder FLUTE HEAD Machine Problems, Solutions , Wireless DNC, serial port 16 09-29-2008 02:21 AM
Has anyone used this edge finder? l u k e General Metalwork Discussion 34 03-19-2008 02:52 PM
Laser edge finder dave6 Calibration & Measurement 9 12-10-2006 10:06 AM
anyone know where to get this optical edge finder? mbwittig General Metal Working Machines 6 10-24-2006 02:33 PM
Anyone have a edge finder G-code routine? InspirationTool General CNC (Mill and Lathe) Control Software (NC) 5 10-02-2006 08:48 PM
