aux axis on an old hs1 is the tool changer dc motor driven by the board mounted on the door of the electrical cabinet you need a read out to see what the alarm is on the aux axis card is the indexer full fourth or do you use a control box?
HS1 with auxillary axis disconnect alarm? What is causing it? I could reset and it would come back again. We have Haas indexer attached to HS1. Auxillary axis means something to do with indexer?
teal854t,
What do you think about your HS1? Is it a good machine? Are the tolerance reliable? Thanks for your feedback.
Jorge
