Old 07-07-2007, 09:48 PM
UBRacing is on a distinguished road
Grease nipples on VF0 x axis?
I pulled the way covers off my VFO and noticed there is grease nipples there for the x axis . How often do they need grease and what kind of grease?
Is there grease nipples on the y axis also?
Old 07-07-2007, 10:06 PM
SORCHEROR is on a distinguished road
does the machine have a lube oil system on it?if the grease fittings are under the way covers i doubt they are being used,my machine doesnt have the oil lude system and needs to be greased once a week or twice if you run it alot,but my fittings are all easy to acess without removing any covers,standard lithium grease is what i use,i hope you havnt run it for too long without lube,check your manual,good luck
Old 07-07-2007, 10:32 PM
Can you also see lube lines? You have a '95 machine, maybe the parts they used had grease nipples fitted as standard and the lube line connection is in a different place on the linear bearings.
Old 07-07-2007, 10:33 PM
The ways are pressure lubed. I didnt see any thing about greasing in the manual.
Guess that answers my question
Old 07-08-2007, 11:33 AM
My manual they gave me with the machine is for 97. I better pull the covers off again and double check both are pressure lubed.
Old 07-08-2007, 11:40 AM
I think if the machine has a lube tank at the back with a pump you can safely conclude all the axes and ball screws are being lubed.
#1 grease? Have Blue Tree 11 12-03-2006 09:24 AM
M6 x 1.0mm grease fitting N4NV Mechanical Calculations/Engineering Design 5 03-31-2006 05:03 PM
oil or grease? hpghost DIY-CNC Router Table Machines 2 08-30-2005 03:20 PM
Bearing Grease georgebarr DIY-CNC Router Table Machines 1 06-06-2005 05:07 PM
grease?? DLMACHINE Machine Problems, Solutions , Wireless DNC, serial port 0 04-22-2004 01:27 AM
