Old 07-05-2007, 04:23 PM
d-moncrief is on a distinguished road
A Axis problems
I am working on a Haas VF1 software version 9.21a.
Date of Manufacture 12-96
I am not the only one running the machine.
After running a short run of parts that did not use the 4th axis I set up to run some with it.
It is a hrt210.
When I started the program I got a "336 A Axis Disabled"
I hit reset then went to the settings graph and item 30 was set to "Off"
I used the cursor keys to select the hrt210 then pressed enter.
I now get a beep and a note saying "Servo is On ! "
I must admit that I have no clue what was done and the other person running the machine is no longer with the company.
I am thinking there is some sequence of steps that I am missing.
I did not install the 4 axis so I don't know what process to follow.
My skill level is "button monkey"
Help please?
dan
Old 07-05-2007, 04:48 PM
The message Servo Is On meant just that; you were trying to changing something with power applied to the servos. Hit Estop and everything should be fine.
Regarding installing the HRT210 make sure the machine power is OFF. You can smoke things plugging or unplugging the 4th axis with power on...or at least that is what I have been told and I do not plane on testing it.
Old 07-05-2007, 06:29 PM
HaasTech83 is on a distinguished road
Yeah just make sure the e-stop pressed and you should be fine. It's also a good idea to restart the machine after selecting your A-axis. Sometimes your settings/parameters don;t take effect till powered off/on.
4th Axis Problems Syncrude Fadal 6 07-09-2007 10:02 AM
having problems adjusting y axis farr_t JGRO Router Table Design 2 12-04-2006 11:07 PM
BP Series I axis problems jho5820705 Bridgeport and Hardinge Mills 26 10-17-2006 09:03 PM
4th axis problems II little bubba Fadal 10 10-24-2005 08:13 AM
Z axis problems Gregor Machine Problems, Solutions , Wireless DNC, serial port 0 04-25-2003 06:23 AM
