Old 06-28-2007, 01:40 PM
gromit68 is on a distinguished road
Tapping small holes in polycarbonate
I have a job where I tap 15 holes 0-80 in polycarbonate, drilled and tapped thru .125" thick. I have always drilled the holes in a cnc vert mill and hand tapped them using hand tap in a tapper in a drill press. I'm curious if anyone has any advice for doing this in a VF-1 with rigid tapping? This run will be 15 holes per part in 250 parts.
Old 06-28-2007, 01:52 PM
I have tapped plastics including polycarbonate althoug not that small. You should have no problems except watch for chips curling around the tap and getting in the way on the next hole. Probably when you are hand tapping you have had to brush the curly chips off between holes. How you can do this in the machine I don't really know; clamp a toohbrush somewhere and have the machine move over and brush the tap off between holes ?
Old 06-28-2007, 03:36 PM
axis is on a distinguished road
use a form thead tap or a roll form tap there are no chips
Old 06-28-2007, 04:23 PM
ltmquik's Avatar
ltmquik is on a distinguished road
Use a roll form tap. For 0-80 use 1400 RPM and 17.50 IPM and coolant on. Applying a bit of stick lubricant or applying some cutting oil to the holes prior to tapping will help also.
Jeff Lange
Lightning Tool & Manufacturing, Inc.
Old 06-29-2007, 04:33 AM
Surfacefeet is on a distinguished road
You should have no problem doing them with the Rigid Tap on your machine.
Tapping very small holes on titanium DIYist General Metalwork Discussion 9 03-17-2009 02:34 PM
Drilling very small holes William Demuth CNCzone Club House 7 12-21-2008 04:56 PM
deep drilling small holes in aluminum Fremont Dave General Metalwork Discussion 13 11-25-2007 02:03 AM
Spindle Speed for tapping 1/4-20 holes. Loading General Metalwork Discussion 32 08-16-2006 10:28 PM
circular interpolation of small deep holes rchprks General Metalwork Discussion 9 11-25-2005 09:37 PM
