Old 06-28-2007, 11:09 AM
binzer is on a distinguished road
Haas rapid move ?
Ok so one haas the rapid moves follow just like gibbs cam shows, the other haas machine doesnt? Its hard to judge where to put the clamps.
Old 06-28-2007, 03:37 PM
axis is on a distinguished road
slow you rapids on the first pass
Old 06-28-2007, 08:11 PM
HuFlungDung's Avatar
Moderator
Solution: don't rapid so close to your surface that you cannot clear the clamps
In rapid traverse, both X and Y move at full speed simultaneously (looks like a 45 degree angle), until either of them reaches its endpoint, then the remaining axis continues to move alone. So it will look like a combination of 45 degree moves, finished with moves parallel to one axis.
A more modern cnc may have enough capability to actually perform an interpolated move at rapid speed, I know I had the option to pick either mode on a Mitsubishi cnc.
You will have to visualize how this works, because the CAM software most likely calculates an interpolated path (bee-line) between two points.
Run the graphic check on the Haas to double check, I think it shows the actual rapid path.
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 03:46 PM
rapid speed contractdesign Bridgeport and Hardinge Mills 6 06-04-2007 10:23 AM
Crash during Z rapid move AndyB Fadal 1 03-07-2007 09:48 AM
Rapid moves G00 dicksonhof Mach Software (ArtSoft software) 9 11-07-2006 10:21 AM
The X-Axles... to move or not to move! Wild4aces Mechanical Calculations/Engineering Design 1 03-18-2005 02:26 PM
