Old 06-26-2007, 12:51 AM
stebanski is on a distinguished road
Question Roll form tapping questions
Does anyone know how large of a thread can be roll form tapped and how well does it work in cold rolled steel and stainless and brass for that matter?
I have used roll form taps in the past but only in aluminum and sizes less than 1/4".
I also wonder about using them in a comp/ret tap driver in my VF-2.
I'll bet at least one of you guys has experimented with all of the available options.
I'm trying to first elminate digging chips out of blind holes, and second, cut down on tap breakage. Seems like I heard somewhere that roll form taps take less torque and provide a better thread.
Any experiece in this area would certainly be of help.
steve
Old 06-26-2007, 03:12 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
they can be used on steels ,
never tryed brass , but i can t see why not
Old 06-26-2007, 05:39 AM
gsrmmeza is on a distinguished road
at work we tapped 1 inch x 12 tpi in steel.
we had to make a sleeve for the tap an put
it into a 1 inch cat 40 holder. there is a hole
in the sleeve for the set screw and a flat on
the tap. we have tapped thru 2.5 inches thick
without problem. the only special thing we do
is mix grease with tapping fluid an coat both the
tap and the hole. since we have to make the
threads to a class 2b tolerance we just have
to keep an eye on the compression/minor diameter.
we have a vf2 with a geared head.
Old 06-26-2007, 09:25 AM
drewmeister is on a distinguished road
i have never used roll taps, but I have thread milled before with very good results. You can go as big as you want and are very easy to program.
Old 06-26-2007, 09:47 AM
taylors is on a distinguished road
95% of the metal I machine is 304L stainless. And roll form tapping is all I will do. It is virtually maintenance free when set up right. Here is a link for a Balax tap catalogue. It has some very usefull info in it.
http://www.balax.com/catalog.pdf
Old 06-26-2007, 10:03 AM
Thumbs up
Thanks you guys. And Taylors, I've saved the link for future use, looks like it should answer all my questions.
Old 06-26-2007, 10:31 AM
Rekd's Avatar
Rekd is on a distinguished road
I've done brass, it works good. I made a small (and free) program to calculate tap drill sizes, and it includes form taps.
Be careful, some customers don't allow form taps on certain parts.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 05-10-2011, 02:29 PM
eljam2000 is on a distinguished road
We are roll form tapping a 1 1/6-10 into steel and going completly thru the part which is 6" long , im currently searching for the best speed for that application, and we are doing this on a lathe.
Any advice would be taken.
Thanks,
James
Old 05-10-2011, 05:14 PM
KenFoulks is on a distinguished road
How big is the material?
How much does it weigh?
How well are you holding it?
What type of steel?
Who manufactures the tap?
What coating does the tap have?
What coolant are you using?
How much coolant are you using?
Are you currently experiencing problems?
What size lathe do you have?
Thanks,
Ken Foulks
Old 05-11-2011, 11:19 AM
What type of steel?
The Material is only 1 5/8 dia. and we are holding it in a collet chuck with serrated jaws and material is 4140 steel. Tap is an OSG tap with a coating but not sure which it is, and we are using Consultant Lubricants Full Synthetic at a 8 on the refracometer. This is currently working just fine and we are using a Doosan 2500, only lathe we had with enough umph and holding force.
  #11   Ban this user!
Old 05-11-2011, 05:12 PM
OSG only carries taps up to 3/4". They do make custom taps, here are their recommendations, based on coating:
Premium 25-30 SFM
Standard 20 SFM
The Doosan 2500 only has 20hp, the same as a Haas ST-20.
Thanks,
Ken Foulks
Vacuum Form Machine Questions? AmazinJane Vacuum forming, Thermoforming Etc 2 10-25-2011 12:03 AM
1/4" mat'l vac form questions elmosxyls Vacuum forming, Thermoforming Etc 19 02-08-2011 09:30 PM
A few questions about a reverse tapping head. l u k e General Metalwork Discussion 14 09-20-2006 09:30 AM
Simple question: Hot roll vs cold roll steel CuttersCov General Metalwork Discussion 1 02-16-2006 08:38 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 09:10 PM
